PostPosted: Sun Aug 01, 2021 3:52 pm
Hey guys, I am back here again this time for a different issue. I use 2 mp3 software players OTSAV and Mediamonkey to auto run and crossfade my fav playlists of mp3's however, they both do not natively support VST plugins so I am trying to find a way to play my mp3's with VST fx, can ST help do what i am seeking in any way please?
I can route both mp3 players Outputs which works with Asio and Wasapi through any DAW or VST Host program but issue I am having is with all of the re-routing involved, seems no one so far is able to come up with a solution and I can't find a DAW with as good a media player as those 2 mentioned.
PostPosted: Sun Aug 01, 2021 8:15 pm
Stereo tool can run as a .VST or VST3
PostPosted: Sun Aug 01, 2021 8:42 pm
Thanks so it should work to connect the VST fx to my MP3 players right?
PostPosted: Fri Aug 27, 2021 3:29 pm
Since you're also trying out BreakawayOne, you should know its VST host can run the 32 bit VST2 of Stereo Tool. In case you want that extra bit of control on the input. This is where I use True Bass in my setup.
PostPosted: Fri Aug 27, 2021 4:27 pm
Ok, will advise Erik, appreciate it.
