PostPosted: Tue Jul 27, 2021 11:47 pm
I suppose I could try things before asking, but getting an answer could save me a hassle.
I'm trying to clean the hum out of some albums. I was able to isolate the hum and create a file of it alone. I want to use the command line version to create copies of the albums without the hum.
Can I train the GUI version and have the command line version use the results?
PostPosted: Sun Aug 01, 2021 8:17 pm
I don't use the command line version but.... if you would want to get rid of the hum of a ground loop or band cables head to the eq section and put this in: 60 Hz -10 db Q8. Should get rid of that if your in US. If your your in a different country swap 60 hz for 50hz.
PostPosted: Mon Aug 02, 2021 9:16 pm
Thanks for the suggestion even though it does not help.
The hum spans most of the spectrum with the highest point around 200Hz. There's a lower pop about once a second.
When I first got Stereo Tool, I don't remember having a problem figuring out how to play, process and record the outcome from the same computer, but I can't wrap my head around it anymore.
PostPosted: Mon Aug 02, 2021 11:13 pm
To answer my own question. You can indeed train the dehummer in the UI version, and then load the sts file with the command line version, and have it work.
