 Post subject: Stereo Tool 3.40
PostPosted: Thu Dec 04, 2008 12:47 am
Stereo Tool 3.40 is now available on the download page!
If you are using Stereo Tool for FM broadcasts, or if you're using the Loudness filter, this update will give you far better results than previous versions.
Changes w.r.t. version 3.30:
  • Loudness filter: Completely rewritten. Now reaches much louder sounds (up to +12 dB) with far less effects on the sound quality. Even notoriously difficult sounds such as xylophones are now handled without introducing distortion.
  • Added FM transmitter calibration. If you are having problems with your FM signal (caused by low quality transmitter equipment, sound card, long cables etc.), you can now configure Stereo Tool to accomodate for that. (On my system, stereo separation is increased by 15 dB after calibrating!)
  • Composite limiter now operates at 705.6 or 768 kHz. This removes peaks that were introduced by the lowpass filter of the sound card.
  • Hard limit now operates at 352.8 or 384 kHz. This removes peaks that were introduced by the lowpass filter of the sound card.
  • Removed the Loudness ++ option because it is no longer needed.
  • Tweaked the presets to take advantage of the improved Loudness filter (more punch).
The CPU load is roughly identical to that of version 3.30 in Low and Normal quality mode as long as the composite limiter oversampling is not used. And it will be a lot slower on PC's without SSE2 support.
 Post subject: Re: Stereo Tool 3.40
PostPosted: Thu Dec 04, 2008 9:49 pm
oua super sound hans :o
And your last version run perfect on my pentium dual core now ;)
Thank you for your work
PostPosted: Fri Dec 05, 2008 12:08 pm
Super!, even weer testen.. zal binnenkort even registreren...
Thx,
Vamprecords
