 Post subject: PLEASE HELP((((
PostPosted: Fri May 21, 2021 1:55 pm
Hi friends. I need a preset with that sound. Who can? Here is the link https://www.radiorecord.ru/
 Post subject: Re: PLEASE HELP((((
PostPosted: Sat May 29, 2021 4:01 pm
It Sounds like an Orban Optimod Audio processor.
It is very difficult to replicate this sound with stereo tool.
I tried and I never really got it to sound like that.
You can take a look at all the standard presets from Stereo tool. You might find something that sounds similar.
PostPosted: Sun May 30, 2021 9:12 am
Thx :cry:
PostPosted: Sun May 30, 2021 11:40 am
If you are not happy with it, you can try one of my older Presets.
Here is a link to my presets : viewtopic.php?f=10&t=30036&start=10
Try 8282 Hot AC or 8282 More clean.
If it doesn't fit, try this Preset : viewtopic.php?t=4046
It's old but good!
PostPosted: Tue Jun 01, 2021 2:05 pm
It's old but good!
Thanks, now I will try to install))) 8-) 8-) 8-)
PostPosted: Tue Jun 01, 2021 2:16 pm
It's old but good!
This preset is the best I've listened to. OM8282 More Clean.sts :o :o :o :D :D :D
