Post new topic  Reply to topic  [ 17 posts ]  Go to page 1 2 Next
PostPosted: Mon Mar 15, 2021 2:10 am
StereoTool is among the most useful software packages I use. I am impressed at the innovation & brilliant problem solving skills of Hans. Few engineers have impressed me as much! However, I'm a bit fuzzy on how the TILT is used in the declipper. Perhaps it is the short explanations when you mouse over the interface features that are confusing me? I'm not sure. However, I have had good experiences with the declipper - although an in-depth video tutorial would be helpful. Especially - TILT. I routinely observe audio on the scopes that clearly is clipped and tilted - and even with good declipper results - this form of clipping is still prevalent in some of my music & I think the solution lies in a better understanding of HOW the available controls in ST can be used to declip a tilted section of audio. Any suggestions or references?
PostPosted: Sat Mar 27, 2021 1:43 pm
Tilting depends not only from the software which you are using to fix your audio. It depends from another critical factor which is your transmitter and especially your pll. A good pll with dual speed loop is a good start in order to get rid the annoying tilt.
PostPosted: Tue Mar 30, 2021 8:39 pm
Hi, sorry for the slow response. What tilt basically does is, it tries to de-tilt the audio before detecting clipping. As you can see in many files, if a tilt has been introduced after clipping, then detecting clipped audio is no longer a matter of just finding samples at the same (and highest) level, but instead you need to tilt the audio first to make those peaks flat.
It's a bit hard to explain, the default settings were created based on some worst-case recordings. But there may be even worse out there that we haven't seen.
To get an idea what tilt does, you can use the RC slider for the FM output and check what it looks like on clipped audio or on square waves. The de-tilt filter basically tries to find the best RC value match for every piece (a few dozen ms) of audio.
PostPosted: Wed Mar 31, 2021 5:25 am
Hans lets suppose that we use the rc correction in order to eliminate tilting of transmitter and we do this successfully, but I'm wondering if this action influence the quality of audio which produce our sound card.
PostPosted: Wed Mar 31, 2021 5:58 am
He was asking about Tilt in Declipper and that has nothing with outputs HD or FM.
Tilt is simple. It occures in every analog path, input or output. Even if you have one analog ideal output, like all say Marian Trace soundcards, in our applicatioons we need to attach it to transmitter MPX input. And that input is not ideal, so again need some Tilt adjustment to be perfect anyway.
For good DeClipping only one thing is needed, good input tilt. I think ST is only program that has Input Tilt adjustment (standoalone), wich is ideal for analog inputs. DeClipper internaly also looks for already clipped and then tilted tracks up to 45deg by default. So probably meets 99.9% tracks that exist. So DeClipper basically by default can be just turned ON and forget about it.
Manually adjusting for specific track is possible by using input Tilt and watching scope to make tilt fine so Declipper can do it's job easier.
PostPosted: Wed Mar 31, 2021 6:15 am
Hi Bojcha.
How we could adjust the input of st ? Like tilting on fm output? By producing square wave of 60hz and trying to optimize with rc correction of input?
PostPosted: Wed Mar 31, 2021 5:18 pm
Hi Bojcha.
Input tilt, just play 30-60Hz Squere tone from your usuall source/player/playout, go to ST and watch input scope.. horizontal lines should be 100% horizontal. And this is only if your ST input is Analog. With digital/network/etc input should be already ideal, i anyway always check. ;)
Output FM Tilt is same but bit tricky, You need to have really good tool to measure that squere tone from your transmitter, from AIR. Erlier I used my Kenwood tuner with MPX output to my USB 192kHz soundcard. All that calibrated with Rohde-Schwarz Unit - Tilt and MPX level.
Now it's waaay easier for me since u use MPXtool with SDR.
You can also do it with Pira.. play squere tone and tune Output Tilt so MPX output level need to be lowest as possible, meaning horizontal line is ~100% horizontal
PostPosted: Thu Apr 01, 2021 4:36 am
Thank you Bojcha for these details. I have tried to optimize the input of st with rc correction by producing square wave of 60hz from my laptop which is my source, but on the scope of st i couldn't see a normal square with horizontal lines.
Regarding tilt on output i' m using pira analyzer but before feed with my mpx the transmitter i make rc correction with my oscilloscope. The problem after this action is that transmitter needs different rc correction in order to achieve the minimum tilt of mxp on air.
PostPosted: Thu Apr 22, 2021 7:15 am
In my experience tilt might not work correctly, unless this has been changed in the past year without any mention in the update notes. See here: viewtopic.php?f=15&t=28287
PostPosted: Sat Jul 10, 2021 7:13 pm
Hey Hans, in the Metallica Album Death Magnetic, if you zoom in on the waveform, the signal is not only heavily clipped, but you can also see a very clear tilt downward of around 15 degrees in the flat peaks across say 100 samples. Is this what you are talking about? If so, when I get back home I can upload an image of it. BTW, What the heck plugin would have caused that in the mastering stage when they made that fatiguing album?
