 Post subject: Emulate radiostation
PostPosted: Sat Feb 05, 2011 6:39 pm
Hello !
Is possible with Stereotool emulate sound of this radiostation: http://188.40.54.131:8000/listen.pls ?
Thanks !
 Post subject: Re: Emulate radiostation
PostPosted: Sat Feb 05, 2011 10:33 pm
Hi Iggy..
Very possible. First if you like how this AAC codec sounds you need to stream at AAC too. (56 or 64k)
For home listening processor cannot emulate codec-sound
processing:
- Load Web Addiction v9 preset and set loudness to x1.15. you will be very close.
- You maybe need to push last 3 bands in MB up a bit.
- Set pre-emphsis to 25us
pozdrav ;)
PostPosted: Sat Dec 24, 2011 1:26 am
Hello !
Sorry if I return to this topic I did not understand your previous post.
Is possible with Stereotool emulate sound of this radiostation: http://www.deejay.it/dj/radio/onair/lowdef
Thanks !
