PostPosted: Mon Jan 25, 2021 10:52 pm
Hi. So I've been messing around with Equalizer APO for various headphone virtualization methods. It allows a 64 bit VST2 to be loaded before the headphone downmix.
My question is whether the 64 bit VST2 (of perfect declipper specifically) supports more than two channels in and out. I'd like to declip the individual discreet channels before they get downmixed and virtualized into stereo. Doing it after doesn't work as well because the peaks have all moved.
Also, the displays don't appear to work in this plugin host, and it crashes upon trying to spawn the GUI a second time. Secondly it keeps beeping at me as if I'm unregistered, and this is not the case according to the GUI. I suppose I'll post this latter part in the bug reporting section.
PostPosted: Mon Feb 01, 2021 8:53 am
After some testing, channel isolation, and manipulation of settings, it appears to attenuate all channels when I isolate them. So I believe this is working to declip each channel independently before the downmix.
Also, the displays don't appear to work in this plugin host, and it crashes upon trying to spawn the GUI a second time. Secondly, it keeps beeping at me as if I'm unregistered, and this is not the case according to the GUI.
However, this is now the glaring issue. I can stand not seeing the meters, but I can't deal with the registration reminder beep or the way the settings reset every time.
