PostPosted: Sat Dec 05, 2020 4:38 am
I downloaded MICRO MPX for Raspberry PI2/3/4 and hifiberry ready-to-go Raspbian Buster image. It is the download option right at the bottom of the STEREO TOOL download page. Then burn the image to a SD Card and insert it into my new Raspberry PI4B with 2GB of ram. But it does not run. After just a few seconds after powering up, the Raspberry Board flashes 4 long and 4 short code. According to the flash codes it means: Unsupported Board Type. This is a new Raspberry PI4B and it looks slightly different than the previous one I bought. But if I use that same image on my "older" Raspberry PI4B it runs without any issue.
Can someone please do a test with the latest version of the Raspberry PI4B 2GB and see if you get the same issue?
I cannot load pictures to show the difference between the latest and the previous Raspberry PI4B boards.
PostPosted: Sat Dec 05, 2020 3:01 pm
That is question for that OS developers.
