Post new topic  Reply to topic  [ 125 posts ]  Go to page 1 2 3 4 513 Next
 Post subject: Stereo Tool 9.63 BETA
PostPosted: Tue Nov 24, 2020 7:17 pm
Latest version - Beta 043 (February 24 2021)
Downloads
Changes/bugfixes
  • Bug fix: Singleband compressor in Analog mode: Output levels above 0 dB did not always work.
  • STX: Entering IP address on screen fails, keyboard disappears. Merge needed.
  • True Bass: Added on/off setting for Sub Bass Boost to main page
  • Highest vs lowest highs: Created separate setting for non-legacy behavior, difference is too big.
  • Update presets
  • Add J.C. preset
  • Update STX/SST presets
  • STX disable most warnings/errors, at least on front panel
  • MicroMPX D license
  • STX: Login mechanism (at least add password reset/disable): Add reset. Test. Plus: Add "logged in as", then probably disable for this release?
  • Update version numbers
  • uMPX library issue? (Does not reproduce here, CPU load problem?) - No, was external issue
TODO's
  • Stereo Tool Enterprise fixed buffers after changing sample rate, ASIO input channels. To be tested -> BROKEN, wait for update.
  • Disable login for release
  • Remove soname for D version
  • Check for printfs in uMPX library
  • Command line version: Show error if .sts file cannot be loaded.
  • Check libVLC crash behavior (UEC)
  • STX wait for mu fix
  • Release
  • Highest vs lowest highs setting issue (see post Bojcha)
  • Updated Windows non-ASIO latency behavior to be more resilient on systems with high CPU load. To be tested.
  • Updated PortAudio to latest version (might fix Mac audio issue, possibly also some Wasapi issues)
  • Increased Wasapi/MME/Kernel Streaming latency setting (use ASIO for low latency, this may be more stable) - feedback wanted
  • Improved Leif's Highs Gap Protection in non-legacy mode (was introduced in 9.63, but broken in several ways).
  • Stereo Tool Enterprise: Several threading/sample rates issues solved, hopefully no bugs are left.
  • Add way to override sound card block sizes (at least for Linux, probably also useful for Windows)
  • Login: Per session
  • Login: Update editable status
  • Login: Hide things
  • Login: Show warning when trying to change something without access
  • Put backup file upload in web interface for MicroMPX
  • GTS
  • STX: Edit whitelist on unit
  • Remote jrtplib
  • Create/include BIMP presets
  • Stereo Tool Enterprise: Think of good name
  • Stereo Tool Enterprise: Switching between devices/channels can go wrong
  • Stereo Tool Enterprise: Sample rate mismatch detection is not ok for ASIO inputs
  • Pi PiMP stand alone BUSY
  • Pi AM stand alone
  • ABE GUI BUSY
  • Release
  • Add "Combp phase"-like test tone to uMPX (FB chat Cleiton Araújo)
  • Stereo Tool new I/O framework: Add bypass mode
  • MicroMPX: Silence detector with backup player (timeout - threshold - time ok before going back to stream)
  • Clipper detect where highs are killed and compensate for that
  • Block multiple instances (avoid running multiple Stereo Tool instances with the same settings)
  • Later: MicroMPX: Export version, bitrate and redundancy info in webinterface and library
  • Later: MicroMPX: Export user messages in library
  • Some pages remain visible when you're logged out (password protection)
  • Later: STX: Overview page with meters
  • Monday: Fill new site BUSY
  • Monday: Pens BUSY
  • Tuesday: Make multi-instance version available
  • Tuesday: Add SST multi-instance interface
  • DSP code - on hold
  • MicroMPX decoder 2nd port number - with pull-down menu, and indices.
  • Stereo Tool priorities: Check what prio 15 things are
  • LiquidSoap/Centova setup manual, maybe add some features
  • Website BUSY
  • Support Contract
  • Improve Advanced Limiter shape (Bojcha) -> Problem is not what it seemed to be! There's a memory problem between chunks of audio, solution is to keep track of what happened in the previous block, and keep the previous audio.
  • Improve Advanced Bass Distortion Protection
  • Compressor with curve drawer
  • Disable stereo widening when detecting low bitrate MP3s
  • Add a checkbox under Delossifier that makes Absolute Highs fix the highs.
  • STX: Verify high frequency tilt behavior
  • Put Declipper presets in ST. Selecting one with "APPLY" overrules all existing settings.
  • BS412 bug: For Quality > 100, the compressors are off by a few dB (probably 1.5x or 2/3rds).
  • How to synchronize HD? THU
  • Measure HifiBerry stereo separation -> Improved from 35 to 55 dB. Make RC work with Ignore high frequencies -> Later
  • Loudness project
  • Linux command line version with AES67 input so output can be streamed - seems to be useful... Other options (run a script for the output) might be easier.
  • Finish 9 - final uMPX file name issue -> In next 9 update.
  • PhoneBooster make multi-threaded if needed (it probably is, esp. for Pi)
  • WatchCat add CMD /C
  • Thimeo School
  • ABDP remove stuff that's no longer needed? BUSY for low CPU
  • Optimize ABDP
  • Sooth effect
  • AES67: Add WheatNet
  • HD delay
  • Documentation: "Processing" page contains all kinds of BS412 info - why?
  • Declipper L/R noise
  • Add resampler
Downloads
Changes/bugfixes
  • Improved FM clipper high frequency output (more high-highs with little impact on the rest of the sound); turn "Legacy highest vs lowest highs priority behavior" off and adjust the level (lower) if needed.
  • Disable Bass Boost if True Bass is disabled
  • MicroMPX: Add bitrate (decoder) and level (both) to library interface
Latest version - Beta 039 (February 17 2021)
Downloads
Changes/bugfixes
  • STX: Add factory reset
  • Added L/R band linking/channel separation level compensation, sounds more open, with louder vocals when other instruments kick in.
  • Added MicroMPX specific customer license target (3rd)
  • Stereo Tool Enterprise: Re-enabled libVLC, not yet tested
  • Stereo Tool Enterprise: Some code cleanup, some small issues fixed
Latest version - Beta 037 (February 14 2021)
Downloads
Changes/bugfixes
  • Error caused by low latency fix (switching latencies could cause lockups) in BETA035, appears to be solved now.
  • Stereo Tool Enterprise: Probably fixed an issue with quickly removing/adding an instance
  • GUI: Fixed an issue when selecting an empty line in the preset selection pulldown (caused the preset to appear to be unselected).
  • STX: Checkbox next to slider: Left part of slider controls checkbox -> Active area was too big
  • STX: Size of scopes in top bar not high enough (doesn't seep to respond to zoomfactor) - fixed, but check MicroMPX etc
  • STX: Removed Basstardizer from top menu
  • STX: Editing PI code was buggy
  • STX: Save multiple times creates multiple copies of the preset under Recent presets -> Planned to stack older versions later, leaving this for now.
  • STX: Make headphone symbols for difference mode more visibly active, and remove weird block above it when selecting.
Latest version - Beta 036 (February 11 2021)
Downloads
Changes/bugfixes
  • Low latency mode was broken since an earlier beta
  • Enterprise buggy in BETA034, hopefully ok again now - although there are more issues left that might cause problems.
  • Add BIMP DeReverb to main path as well
  • Bug in ShoutCast code, user:password didn't work
  • Put DeReverb also in main path (hidden?)
Latest version - Beta 034 (February 8 2021)
Downloads
Changes/bugfixes
  • IceCast/ShoutCast streaming was broken on XP, works now
  • MicroMPX Decoder library: Export FEC etc info
  • MicroMPX library: Support opening multiple instances
  • MicroMPX: Added dynamic thresholds in V4. THIS BREAKS COMPATIBILITY WITH EARLIER V4 VERSIONS!
Latest version - Beta 029 (January 27 2021)
Downloads
Changes/bugfixes
  • Stereo Tool: Selected preset name wasn't displayed if there was only a single preset in the list (which could happen in Recent Presets) since after BETA007
  • Stereo Tool: Solved command line version crash when trying to determine where to store settings file, since after BETA007
  • Stereo Tool: Closing GUI in Linux was somewhat broken, since BETA007
  • Stereo Tool Enterprise: Lots of smaller issues fixed
Latest version - Beta 028 (January 24 2021)
Downloads
Changes/bugfixes
  • STX: Fix ugly bars in web GUI with zoom factor
  • MicroMPX: Add Nice levels
  • Stereo Tool Enterprise: 2nd input (BIMP etc) does not work properly.
  • Document JSON interface - done, in MicroMPX documentation appendix
  • Stereo Tool: Presets were not visible in SAM Broadcaster after startup since after BETA007
  • MicroMPX: Report: Enable/disable GPS will keep sweeping as if GPS is on until restart -> No, I don't see that here.
Latest version - Beta 021 (January 13 2021)
Downloads
Changes/bugfixes
  • Fixed web interface in BETA020, added build script check to assure this won't happen again
  • Run Stereo Tool MULTI-INSTANCE as a service: Stopping fails (hangs)
  • JSON reset log: How, and add JSON stuff to manual - Also increased maximum number of errors from 10 to 32.
Latest version - Beta 020 (January 12 2021)
Downloads
Changes/bugfixes
  • MicroMPX V4: Fix 32 bit Pi crash - Compiler bug/feature? (took several days to find/fix)
  • BETA018: After closing twice, name of loaded preset disappears (also took several days)
  • STX/SST: Shrink everything to 85%, but not MicroMPX (own style?) DONE
  • Verify STX installer - Failed, probably fixed
  • Mac .zip file installer for VST's - for now anyway DONE
  • 2 w zip DONE
  • BETA018: Loading presets from webinterface fails
  • BETA018: Uploading presets fails. (ST)
Latest version - Beta 018 (December 24 2020)
Downloads
Changes/bugfixes
  • Save passwords ONLY to .ini file
  • Mac builds are now signed for Catalina
  • SST error for bad license was not visible
  • MicroMPX: New V4 encoding (for testing only, compatibility might still break before release). V4 has a slightly improved encoding at 45% less CPU usage. And it allows bitrates upto 900 kbit (possibly even more)
  • MicroMPX library: removed C++11 dependency, added void* for user info for callbacks.
  • MicroMPX: Encoder was not enabled in FM Professional EVENT license?
  • MicroMPX: Encoder bug in keyframes fixed, for all MicroMPX versions. Could cause some (very soft, -60 dB or so) noise at the start of keyframes.
  • MicroMPX: Encoder bug in Huffman table transport fixed, for all MicroMPX versions. Very slightly improves the encoding.
  • STX and MicroMPX web interface: Shrunk everything to 80%, waiting for feedback (maybe it's too much?)
Latest version - Beta 002 (November 24 2020)
Downloads
Changes/bugfixes
  • WatchCat updated!
  • "Basic" mode AGC -> Per Band display is bad (other modes as well, just not as bad as this one).
  • Backup soundcard doesn't work? - broke in 9.60, fixed now.
  • VST2 plugin hangs in Audition on close -> Fixed, closing changed
  • MicroMPX library: decoder buffer stuff for customer. Also turn off sound card restarts,
PostPosted: Tue Nov 24, 2020 7:19 pm
There is a new WatchCat beta!
Wooo! I'll definitely be messing with it soon. Thanks for the update!
EDIT: I tried installing a few times, and kept getting this error. Win10x64 20H2
EDIT2: Solved, thanks!
PostPosted: Tue Nov 24, 2020 7:25 pm
Saw it here as well, re-uploading with the correct DLL included now. Give it 2 minutes...
Edit: These are loooong minutes.. nearly there.
Done! Last update (bigger windows, when they open they are way too small now) wasn't yet included in this one, that will probably also come tomorrow.
PostPosted: Tue Nov 24, 2020 8:01 pm
Alright, now I'm getting strange tones that I assume are supposed to be only in demo mode. However, upon loading a preset with everything disabled, it still occurs. Does WatchCat think I'm using some unlicensed feature? I'm certain the pre and post-processing effects are disabled.
It would be handy for this information to be in the error log. Specifically regarding whether it's trying to apply settings without the proper license.
edit: Here's what it looks like in a linear spectrogram.
PostPosted: Thu Nov 26, 2020 11:18 am
Switching on TA on RDS section with commend http://{target machine ip}:­8080/­121=1 still don't work. (yes, web inferface is enabled)
PostPosted: Thu Nov 26, 2020 5:33 pm
Stereo Tool multi-instance version
Excitement!
Does that mean we can run multiple instances on Linux/Jack?
PostPosted: Thu Nov 26, 2020 6:18 pm
Hans, do you already know approximately when you want to provide PhoneBooster as a plugin variant (similar to the declipper) or integrate it into StereoTool? I would have some use cases and test cases for it, but for that I would need the whole thing as a plugin and not as a separate program.
PostPosted: Thu Nov 26, 2020 8:31 pm
Excitement!
Windows for now, but that would be a good next step. (Well you can already run multiple intstances? But this is 1 process with an overview screen etc).
PostPosted: Fri Nov 27, 2020 2:19 am
How is the way to use as multiple instances?
https://fmfeeling.com
PostPosted: Mon Nov 30, 2020 2:15 pm
Excitement!
Actually no, we can't really run more than one instance in Linux/Jack. Simply because a) the jack client name, which must be unique, is fixed to "stereotool" (and I don't like messing with the hex editor to change letters), abd b) all settings are stored in ~/stereotool.rc (or similar), so will get overriden bei whichever instances closes last. That gives funny results on startup. That's why some of us asked for command line options for the GUI on linux to sepcify jack client name and sts file to load.
But having multiple instances in ONE gui would be better, of course.
