Hello. This is my third attempt at a preset. This time using the concept of "less is more," so hopefully it won't be too much. It requires the Declipper, 4-band AGC (Advanced Dynamics package), and Advanced Clipper (Basic) licenses and also makes use of deep bass synthesis (True Bass and Sub Bass Boost). Built using version 9.61
It was built using Spotify's "quiet" music normalization setting and aims to hover between -18db and -12db (preferably around -14db) in the measurement tool. If there's too much or too little bass, start by adjusting the Deep Bass Synthesis on the Quick Adjust panel of the main page and adjust the clipper loudness to taste.
File comment: No multiband or BEQ. Re-adjusted AGC bands.
ginger-43ef.sts [132.77 KiB]
Downloaded 505 times
File comment: Heavier processing, ( adds multiband/AEQ/BEQ/IB/BC)
ginger-40w.sts [132.73 KiB]
Downloaded 480 times
File comment: Initial Release (DC/AGC/TB/SubBoost/Clip)
ginger-04.sts [146.96 KiB]
Downloaded 511 times
