PostPosted: Fri Oct 16, 2020 7:32 pm
Hey folks.
When using Discord to capture and stream the Stereo Tool application, it doesn't pick up any audio. I like to stream music on rare occasions to my friends in my Discord server, and the simplest way to do it would just be to capture the application's window if it contained audio. Is there a way to make this work by choosing the correct output? Or would it require that capability to be programmed into the Stereo Tool application itself?
Thanks!
PostPosted: Fri Oct 16, 2020 9:42 pm
Hey folks.
Thanks!
That's not ST problem but Discord problem. You need to turn ON...
PostPosted: Fri Oct 16, 2020 10:33 pm
I wish that solved it, but alas I've tried all settings like this in Discord, and this one specifically has been enabled since the beginning. Are you certain this is all you did to make it work? What output did you use, etc? Does that matter at all?
edit: I tried both Discord and ST in administrator mode.
PostPosted: Sat Oct 17, 2020 12:28 am
i did not try for ST, but for other programs. well..
PostPosted: Sat Oct 17, 2020 12:32 am
This is what makes me wonder if Stereo Tool handles application audio differently from other applications. And I suppose it makes sense that it would.
PostPosted: Sat Oct 17, 2020 2:25 am
Ok, i just tried ST standalone and it works. discord captures it just fine.
PostPosted: Sat Oct 17, 2020 4:02 am
After some work, I was able to get it working. I'm frankly not sure what I changed to solve it. But I'm able to capture audio directly from ST using the Normal out! Thank you for letting me know it is indeed possible.
