PostPosted: Fri Aug 21, 2020 4:58 pm
Stereo Tool 9.52 Universal USB does not detect sound cards. Is there a solution to this?
PostPosted: Fri Aug 21, 2020 8:24 pm
no.
PostPosted: Tue Aug 25, 2020 1:40 pm
What do you mean by "Universal USB"? Stereo Tool shows the sound cards that are available according to Windows, Linux or OS X. If a sound card doesn't show up it's usually a driver issue. For example, we have seen sound cards that ONLY have 32 bit drivers - in the 64 bit Stereo Tool they aren't shown. Also, a non-ASIO sound card must have 2 channels to be shown.
PostPosted: Tue Jan 02, 2024 4:06 pm
Ooohhh, bummer. That last part explains everything. I don't know where else this info is listed, but it should be somewhere in the Help section for sure, if not somewhere more prevalent, especially for single-channel licenses like MultiVOC. Is this still a hard-coded issue?
edit: Nevermind this next part. RTX Voice/Nvidia Broadcast seems to want to work now... But the initial problem of mono input devices remains.
I see things like RTX Voice (found in the Nvidia Broadcast app) able to be pick up my single-channel input device and then tunnel it to Stereo Tool with increased latency. It won't work in Stereo Tool over WASAPI either, showing an error. Tried 32 bit, 64 bit, 48khz, 44.1khz, 88+khz...
