PostPosted: Tue Aug 18, 2020 9:03 pm
Hey Guys,
Got a weird one for you which is blowing my mind.
Here's the equipment first:
Win 10 Pro 64bit
Asus B360 MB
Intel I5-9400 2.9GHZ LGA1151 CPU (6 Cores)
Gskill 8G Ram
Samsung 250G SSD
Marion Trace Alpha sound card
Stereo Tools Version 9.52
Marion trace driver version 3.0.8.9
Problem:
Works great after install and reboots.
If you power off the PC then restart it I get sound card timeout errors on Stereo Tools.
One of the errors : Sound card reopened after receiving no response from it for 5 seconds.
I have added delay to the startup time to see if that helps but no cigar, I also made sure that I was using the latest Marion trace drivers as well. Ive even went as far as uninstalling stereo tools and the Marion trace drivers and reinstalled. If I restart the machine it will work properly.
I have also built 5 of these machines to replace old ones and the all behave the same.
I really don't know what could be the problem here.
Thoughts or suggestions please?
PostPosted: Tue Aug 18, 2020 9:39 pm
Try to change soundcard slot on motherboard and install driver again. Also try older drivers, one by one.
PostPosted: Tue Aug 18, 2020 9:42 pm
Only one slot.
PostPosted: Wed Aug 19, 2020 12:03 pm
It might be worthwhile updating the BIOS?
Maybe have a look at the chipset driver and see if it is the latest version?
How about disabling all unnecessary onboard devices (e.g. serial port etc.)?
Check / disable power saving settings?
PostPosted: Thu Aug 20, 2020 8:49 am
In the case where you get these errors, are other applications able to play audio to that soundcard? I would assume not.
