 Post subject: PI4 Autostart
PostPosted: Tue Jul 14, 2020 8:46 am
Hello,
I have a PI4 8GB HiFi Berry sound card.
Latest full raspberian version +updates installed.
I can't find a way to have ST start automatically after boot.
I tried all different things from crontab to init.d and upstart job.
Nothing worked.
I can start ST from the terminal.
But again the Autostart will just not
work. I did gave permissions.
If anyone has an idea, it's much appreciated!
Thanks
 Post subject: Re: PI4 Autostart
PostPosted: Fri Jul 31, 2020 11:06 pm
Hint: upstart and init.d run before the graphical session is ready. Stereotool needs a running X-server to render the GUI.
Nowadays, you' dbetter use systemd to start the process. You can add a systemd userservice in
~/.config/systemd/user/
try with something like (this is for the jack-version, alsa won't need the jack.service references)
stereotool.service:
[Unit]
Description=Stereotool
After=jack.service
BindsTo=jack.service
After=graphical-session.target
BindsTo=graphical-session.target
[Service]
LimitRTPRIO=infinity
LimitMEMLOCK=infinity
Environment="DISPLAY=:0"
Environment="XAUTHORITY=/home/pi/.Xauthority"
ExecStart=/your/path/to/stereo_tool_gui_jack_64
Restart=always
RestartSec=2
[Install]
WantedBy=default.target
and then something like systemctl --user enable stereotool
This is very brief, you may need some additional steps.
PostPosted: Tue Aug 04, 2020 1:34 am
Dear Minetti,
Thank you very much for your help!
With your code and some modifications I was finally able to get it running.
For some reason those lines gave me trouble. (It could not be found)
So I had to take those out.
This is the code for SystemD that works for me:
Enabled from /etc/systemd/system/st.service
st.service:
[Unit]
After=multi-user.target
[Service]
Restart=always
RestartSec=10
[Install]
Thanks again,
Cheers
PostPosted: Thu Aug 06, 2020 3:54 pm
For my part to start stereotool when PI4 is starting I use the method 2 describe here:
https://learn.sparkfun.com/tutorials/ho ... -autostart
