 Post subject: Waveform Display
PostPosted: Tue Jan 18, 2011 4:40 am
HVZ,
If I have disabled the waveform display it would be nice if the main Stereo Toll resized to remain the display. The main window runs as "window on top". I would regain some desktop space.
Thanks
 Post subject: Re: Waveform Display
PostPosted: Wed Jan 19, 2011 11:13 pm
Why not use window minimize option ?
Ok, I had the same idea like you.
When I run the Stereo Tool VST version as a wrapped DX plugin and load it with the free VB:FFX4 DX chainer I can resize the window (to cut elements like the inactive waveform/oscilloscope display).
But then it is impossible to access the preset menu correctly.
For standard (system) windows a menu can overlap the actual window size.
But I don't know (I doubt !) if it is possible to have it within the software graphics engine that Hans uses for Stereo Tool ?
PostPosted: Thu Jan 20, 2011 4:49 am
You could also resize the main window through the properties of the window. Is that not possible?
I have done this with other applications. As a "saved" configuration option, this would be done before the main window would be displayed. I am not asking for a dynamic option.
Thanks for your reply.
PostPosted: Fri Jan 21, 2011 12:11 am
With the "size" option ?
Does not work (not here with Win XP pro SP2).
Until now the only way is that I have described (VST version wrapped to DX and hosted with VB:FFX).
