 Post subject: test
PostPosted: Tue Jan 11, 2011 8:56 am
Check this preset, this one would be cool for metal (at least for me :=D)
[Common]
Pre amplifier=6
Post amplifier=0.939999998
Extra loudness=1.200000048
Extra loudness - Allow extra highs (advanced)=0
Extra loudness - Punchy=-0.442499995
Extra loudness - Max Punch peak=0.850000024
Extra loudness - Deep bass protection - Value=0.53974998
Bass protection - Enabled=1
Bass protection - Two steps=0
Bass protection - Clip level=140
Bass protection - Deep bass boost=60
Bass protection - Raise clip level if highs get above=110
Bass protection - Maximum clip level raise=35
Hard limit output=0
Extra loudness - De-esser limit=65650
Extra loudness - Reflection strength=0.099999994
Extra loudness - Allow more distortion=0
Extra loudness - Highs burst strength=1
Extra loudness - New Bass Protection - Very deep bass filter frequency 1=150
Extra loudness - New Bass Protection - Very deep bass filter frequency 2=350
Extra loudness - New Bass Protection - Clip very deep bass at=0.899999976
Extra loudness - New Bass Protection - BassMid filter frequency 1=350
Extra loudness - New Bass Protection - BassMid filter frequency 2=750
Extra loudness - New Bass Protection - Clip BassMid at=1
Extra loudness - Voice vibrations - Highs feedback strength=1
Extra loudness - Voice vibrations - Never reduce bass below=0.400000006
Extra loudness - Voice vibrations - Multiply measured vibration level by=0.899999976
Extra loudness - Voice vibrations - Ignore vibration levels below=0.5
Extra loudness - Voice vibrations - Reduce sensitivity for non-constant sounds strength=1
Extra loudness - New Bass Protection - Strict clipping=1
Extra loudness - New Bass Protection - Strict clipping - More strict=0
Extra loudness - New Bass Protection - Strict clipping frequency 1=250
Extra loudness - New Bass Protection - Strict clipping frequency 2=350
Extra loudness - New Bass Protection - Strict clipping - Clip bass at=0.899999976
Extra loudness - New Bass Protection - Strict clipping - Clip Punched bass at=0.949999988
Extra loudness - New Bass Protection - Strict clipping - Never dynamically raise bass level above=1
Extra loudness - Dirty Bass=0
[Noise Gate]
Enabled=1
Difference=0
Noise level=0.449999988
Relative noise gate level - Band 4=1
Relative noise gate level - Band 5=1
Relative noise gate level - Band 6=1
Relative noise gate level - Band 7=1
[Singleband Compressor]
Enabled=0
Difference=0
Maximum volume=1.5
Attack speed=0.000149978
Decay speed=0.014998496
Above Top Limiter=0
AGC RMS style Enabled=0
AGC RMS style Target RMS level=25000
AGC RMS style Remove remaining peaks above=1.5
[Pre Compressor]
Enabled=1
Maximum volume - Band 1=38380
Attack speed - Band 1=0.000004
Attack speed - Band 3=0.000005001
Decay speed - Band 1=0.001300095
Decay speed - Band 3=0.000249943
Dual band=1
Third band=0
Relative expected volume of highs=0.600000024
Relative maximum volume of highs=3
Relative maximum volume of very highs=0.330000013
Remove remaining peaks above (relative to maximum volume)=1.200000048
Enable smoothing=0
Smoothing time=0
Gating level=0
Use ITU-BS.1770=0
Channel separation=0.300000012
Gating based on volume before Pre Amp=0
Lock bass to band 2 strength=0.5
[Multiband Compressor]
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band -1=2850
Maximum volume - Band 0=4810
Maximum volume - Band 1=5250
Maximum volume - Band 2=6200
Maximum volume - Band 3=6100
Maximum volume - Band 4=6000
Maximum volume - Band 5=5200
Maximum volume - Band 6=4270
Maximum volume - Band 7=3600
Maximum volume - Band 8=1460
Attack speeds linked=0
Attack speed - Band -1=0.000071428
Attack speed - Band 0=0.000060823
Attack speed - Band 1=0.000051715
Attack speed - Band 2=0.000040472
Attack speed - Band 3=0.000043308
Attack speed - Band 4=0.000055309
Attack speed - Band 5=0.00006097
Attack speed - Band 6=0.000070264
Attack speed - Band 7=0.000080762
Attack speed - Band 8=0.000070175
Decay speeds linked=0
Decay speed - Band -1=0.000539601
Decay speed - Band 0=0.0004578
Decay speed - Band 1=0.000398067
Decay speed - Band 2=0.00040043
Decay speed - Band 3=0.000403063
Decay speed - Band 4=0.000400956
Decay speed - Band 5=0.000500126
Decay speed - Band 6=0.000603963
Decay speed - Band 7=0.000703088
Decay speed - Band 8=0.000602316
Above Top Limiter=0.75
Clipping enabled=1
Postprocessing enabled=0
Relative clip position - Band -1=2.508771658
Relative clip position - Band 0=2.636363983
Relative clip position - Band 1=1.985074759
Relative clip position - Band 2=1.702702761
Relative clip position - Band 3=1.777777672
Relative clip position - Band 4=1.777777672
Relative clip position - Band 5=1.631578922
Relative clip position - Band 6=1.500000238
Relative clip position - Band 7=1.17391324
Relative clip position - Band 8=1.127659559
Final limiter value=1
Final limiter decay speed=0.001037534
Final limiter clipping=0
Equalizer enabled=1
Equalizer position - Band -1=1.56410265
Equalizer position - Band 0=1.777777672
Equalizer position - Band 1=1.409638405
Equalizer position - Band 2=1.127659559
Equalizer position - Band 3=0.886792541
Equalizer position - Band 4=0.886792541
Equalizer position - Band 5=0.886792541
Equalizer position - Band 6=1.247190952
Equalizer position - Band 7=1.56410265
Equalizer position - Band 8=1.56410265
Flat frequency response enabled=1
Center frequency - Band -1=43.06640625
Center frequency - Band 0=86.1328125
Center frequency - Band 1=172.265625
Center frequency - Band 2=344.53125
Center frequency - Band 3=689.0625
Center frequency - Band 4=1378.125
Center frequency - Band 5=2756.25
Center frequency - Band 6=5512.5
Center frequency - Band 7=10000
Center frequency - Band 8=15000
[Stereo]
Enabled=3
Stereo AZIMUTH Enabled=1
Stereo Image Enabled=0
Stereo Boost Enabled=1
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=50
AZIMUTH change speed=0.229999989
Image phase amplifier=1
Image width amplifier=1
Extra phase shift=0
Mono or stereo only=0
Stereo Boost strength=9
Stereo Boost maximum amplification=1.350000024
Stereo Boost multiplier=1
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=1
Lowpass filter=16000
Highpass filter=30
Highpass filter linearity=Yes
[Bass Boost]
Enabled=1
Strength=0.505699992
Start lowpass frequency of input filter=80
End lowpass frequency of input filter=350
Start lowpass frequency of output filter=350
End lowpass frequency of output filter=500
Clip level=1.206999898
Preserve louder peaks=1
Difference=0
[Phase Rotator]
Enabled=1
Start frequency=600
Start speed=1000
Number of rotations=4
Smoothness=0.980999947
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1.160000086
Pre-limiter enabled=0
Pre-limiter relative volume=1.899999976
Reduced CPU processing=0
[FM Transmitter]
Enabled=0
Pre-emphasize=0
Pre-emphasis time=50
Output is pre-emphasized=0
Stereo encoder enabled=0
RDS encoder enabled=0
Pilot signal volume=9
RDS signal volume=4.5
FM overdrive volume=1
RDS PS text=2s:STEREO/2s:TOOL/<1=1.5s,2..-2=2t,-1=1.5s:WWW.STEREOTOOL.COM/|\W"PLAYING %artist% - %title% "/1s:\T2h\:\T02m\:\T02s/1s:\T2h\:\T02m\.\T02s/1s:\T2h\:\T02m\:\T02s
RDS RadioText text=60s:Stereo Tool: Professional Audio Processing - www.stereotool.com/30s:Stereo Tool by Hans van Zutphen, 1999-2008 - www.stereotool.com/30s:\W"%artist% - %title% - %album%"
RDS PTY=-1
RDS PI=65535
RDS Alternative frequency 1=0
RDS Alternative frequency 2=0
RDS Alternative frequency 3=0
RDS Alternative frequency 4=0
RDS Alternative frequency 5=0
RDS Alternative frequency 6=0
RDS Alternative frequency 7=0
RDS Alternative frequency 8=0
RDS Alternative frequency 9=0
RDS TP=0
RDS TA=0
RDS Music=1
RDS Artificial Head=0
RDS Compressed=1
RDS Dynamic PTY=0
RDS RadioText Enabled=1
RDS ClockTime Enabled=1
[Direct soundcard access]
Enabled=0
Device ID=Переназначение звуковых устр.
Volume=1
Buffer size=1
Send to Winamp=Nothing
ASIO Override channel 1=4
ASIO Override channel 2=5
[Low latency output]
Enabled=0
Volume=1
Buffer size=0.079999998
ASIO Override channel 1=2
ASIO Override channel 2=3
[FM Hiss]
Enabled=0
Difference=0
FM median pos=25
FM measure max multiplier=2
FM reduce=150
FM delay=2.5
FM delay median=7.5
[Lossy compression output optimization]
Enabled=0
Spike Protation pre-emphasis time=15
hazz_x1.rar [2.92 KiB]
Downloaded 656 times
