 Post subject: IrieUK
PostPosted: Thu Jan 06, 2011 12:57 am
IrieUK Audio settings on stereo tool, take a listen via http://www.irieuk.net via audio streams or cam,
currently audio from mixer > mixing desk > pc (stereotool) > pc to stream / cams
any suggestions or ideas on how to improve?
[Common]
Pre amplifier=20
Post amplifier=1.069999933
Extra loudness=1
Extra loudness - De-esser limit=65650
Extra loudness - Punchy=-0.75
Extra loudness - Max Punch peak=0.75
Extra loudness - Deep bass protection - Value=0.638750076
Extra loudness - Reflection strength=0.099999994
Extra loudness - Allow more distortion=0
Extra loudness - Highs burst strength=1
Extra loudness - New Bass Protection - Very deep bass filter frequency 1=150
Extra loudness - New Bass Protection - Very deep bass filter frequency 2=350
Extra loudness - New Bass Protection - Clip very deep bass at=0.899999976
Extra loudness - New Bass Protection - BassMid filter frequency 1=350
Extra loudness - New Bass Protection - BassMid filter frequency 2=750
Extra loudness - New Bass Protection - Clip BassMid at=1
Extra loudness - Voice vibrations - Highs feedback strength=1
Extra loudness - Voice vibrations - Never reduce bass below=0.400000006
Extra loudness - Voice vibrations - Multiply measured vibration level by=0.899999976
Extra loudness - Voice vibrations - Ignore vibration levels below=0.5
Extra loudness - Voice vibrations - Reduce sensitivity for non-constant sounds strength=1
Extra loudness - New Bass Protection - Strict clipping=1
Extra loudness - New Bass Protection - Strict clipping - More strict=0
Extra loudness - New Bass Protection - Strict clipping frequency 1=250
Extra loudness - New Bass Protection - Strict clipping frequency 2=350
Extra loudness - New Bass Protection - Strict clipping - Clip bass at=0.899999976
Extra loudness - New Bass Protection - Strict clipping - Clip Punched bass at=0.949999988
Extra loudness - New Bass Protection - Strict clipping - Never dynamically raise bass level above=1
Extra loudness - Dirty Bass=0
Bass protection - Enabled=0
Bass protection - Two steps=0
Bass protection - Clip level=140
Bass protection - Deep bass boost=12.899999619
Bass protection - Raise clip level if highs get above=150
Bass protection - Maximum clip level raise=35
Hard limit output=1
[FM Hiss]
Enabled=0
Difference=0
FM median pos=25
FM measure max multiplier=2
FM reduce=150
FM delay=2.5
FM delay median=7.5
[Noise Gate]
Enabled=0
Difference=0
Noise level=1
Relative noise gate level - Band 4=1
Relative noise gate level - Band 5=1
Relative noise gate level - Band 6=1
Relative noise gate level - Band 7=1
[Singleband Compressor]
Enabled=0
Difference=0
Maximum volume=1.5
Attack speed=0.000149978
Decay speed=0.014998496
Above Top Limiter=0
AGC RMS style Enabled=0
AGC RMS style Target RMS level=25000
AGC RMS style Remove remaining peaks above=1.5
[Pre Compressor]
Enabled=1
Maximum volume - Band 1=58800
Attack speed - Band 1=0.000005001
Attack speed - Band 3=0.000021948
Decay speed - Band 1=0.000249943
Decay speed - Band 3=0.000836979
Dual band=1
Third band=0
Relative expected volume of highs=0.649999976
Relative maximum volume of highs=3
Relative maximum volume of very highs=0.330000013
Remove remaining peaks above (relative to maximum volume)=1.75
Enable smoothing=0
Smoothing time=0
Gating level=0
Use ITU-BS.1770=0
Channel separation=0.300000012
Gating based on volume before Pre Amp=0
Lock bass to band 2 strength=0.5
[Multiband Compressor]
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band -1=5250
Maximum volume - Band 0=4920
Maximum volume - Band 1=6440
Maximum volume - Band 2=5760
Maximum volume - Band 3=5590
Maximum volume - Band 4=6270
Maximum volume - Band 5=6440
Maximum volume - Band 6=7460
Maximum volume - Band 7=7460
Maximum volume - Band 8=8140.000488281
Attack speeds linked=1
Attack speed - Band -1=0.000096324
Attack speed - Band 0=0.000096324
Attack speed - Band 1=0.000096324
Attack speed - Band 2=0.000096324
Attack speed - Band 3=0.000096324
Attack speed - Band 4=0.000096324
Attack speed - Band 5=0.000096324
Attack speed - Band 6=0.000096324
Attack speed - Band 7=0.000096324
Attack speed - Band 8=0.000096324
Decay speeds linked=1
Decay speed - Band -1=0.000958171
Decay speed - Band 0=0.000958171
Decay speed - Band 1=0.000958171
Decay speed - Band 2=0.000958171
Decay speed - Band 3=0.000958171
Decay speed - Band 4=0.000958171
Decay speed - Band 5=0.000958171
Decay speed - Band 6=0.000958171
Decay speed - Band 7=0.000958171
Decay speed - Band 8=0.000958171
Above Top Limiter=0.5
Clipping enabled=1
Postprocessing enabled=0
Flat frequency response enabled=1
Relative clip position - Band -1=1.56410265
Relative clip position - Band 0=2.278688431
Relative clip position - Band 1=1.985074759
Relative clip position - Band 2=2.571429014
Relative clip position - Band 3=1.56410265
Relative clip position - Band 4=1.985074759
Relative clip position - Band 5=1.816901207
Relative clip position - Band 6=1.597402573
Relative clip position - Band 7=1.409638405
Relative clip position - Band 8=1.197802305
Final limiter value=1
Final limiter decay speed=0.002235811
Final limiter clipping=2.571429014
Equalizer enabled=1
Equalizer position - Band -1=1.985074759
Equalizer position - Band 0=1.409638405
Equalizer position - Band 1=1
Equalizer position - Band 2=1
Equalizer position - Band 3=1.247190952
Equalizer position - Band 4=1.083333254
Equalizer position - Band 5=1.150537729
Equalizer position - Band 6=1.777777672
Equalizer position - Band 7=1.777777672
Equalizer position - Band 8=1.631578922
Center frequency - Band -1=43.06640625
Center frequency - Band 0=86.1328125
Center frequency - Band 1=172.265625
Center frequency - Band 2=344.53125
Center frequency - Band 3=689.0625
Center frequency - Band 4=1378.125
Center frequency - Band 5=2756.25
Center frequency - Band 6=5512.5
Center frequency - Band 7=10000
Center frequency - Band 8=15000
[Stereo]
Enabled=2
Stereo AZIMUTH Enabled=0
Stereo Image Enabled=0
Stereo Boost Enabled=0
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=0
AZIMUTH change speed=0
Image phase amplifier=0
Image width amplifier=0
Extra phase shift=0
Mono or stereo only=0
Stereo Boost strength=1
Stereo Boost maximum amplification=3
Stereo Boost multiplier=1
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=0
Lowpass filter=9840
Highpass filter=30.000001907
[Bass Boost]
Enabled=1
Strength=1
Start lowpass frequency of input filter=120
End lowpass frequency of input filter=250
Start lowpass frequency of output filter=250
End lowpass frequency of output filter=350
Clip level=1.5
Preserve louder peaks=1
Difference=0
[Phase Rotator]
Enabled=0
Start frequency=700
Start speed=1400
Number of rotations=4
Smoothness=0.979999959
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1
Pre-limiter enabled=0
Pre-limiter relative volume=1.75
Reduced CPU processing=0
[FM Transmitter]
Enabled=0
Pre-emphasize=1
Pre-emphasis time=50
Output is pre-emphasized=0
Stereo encoder enabled=0
RDS encoder enabled=0
Pilot signal volume=9
RDS signal volume=4.5
FM overdrive volume=1
RDS PS text=2s:STEREO/2s:TOOL/<1=1.5s,2..-2=2t,-1=1.5s:WWW.STEREOTOOL.COM/1s:\T2h\:\T02m\:\T02 ... 02m\:\T02s
RDS RadioText text=60s:Stereo Tool: Professional Audio Processing - http://www.stereotool.com/30s:Stereo Tool by Hans van Zutphen, 1999-2008 - http://www.stereotool.com
RDS PTY=0
RDS PI=65535
RDS Alternative frequency 1=0
RDS Alternative frequency 2=0
RDS Alternative frequency 3=0
RDS Alternative frequency 4=0
RDS Alternative frequency 5=0
RDS Alternative frequency 6=0
RDS Alternative frequency 7=0
RDS Alternative frequency 8=0
RDS Alternative frequency 9=0
RDS TP=0
RDS TA=0
RDS Music=1
RDS Artificial Head=0
RDS Compressed=1
RDS Dynamic PTY=0
RDS RadioText Enabled=1
RDS ClockTime Enabled=1
FM Transmitter Calibration - Phase shift 20 Hz=0.25
FM Transmitter Calibration - Phase shift 160 Hz=0.25
[Lossy compression output optimization]
Enabled=0
Spike Protation pre-emphasis time=15
[Direct soundcard access]
Enabled=0
Device ID=Realtek AC97 Audio
Volume=1
Buffer size=1
Send to Winamp=Nothing
ASIO Override channel 1=4
ASIO Override channel 2=5
[Low latency output]
Enabled=0
Volume=1
Buffer size=0.080000006
ASIO Override channel 1=2
ASIO Override channel 2=3
[ASIO]
ASIO Enabled=0
Sound card=
[Soundcard - Normal output]
Enabled=1
Volume=1
Buffer size=1
ASIO Override channel 1=0
ASIO Override channel 2=-1
[Soundcard - Input]
Sample rate=44100
Buffer size=0
ASIO Override channel 2=1
File comment: Irie Settings
irie.rar [2.78 KiB]
Downloaded 755 times
