Post new topic  Reply to topic  [ 41 posts ]  Go to page 1 2 3 4 5 Next
 Post subject: Stereo Tool 9.50
PostPosted: Wed May 13, 2020 12:59 pm
Stereo Tool 9.50 is released!
Changes:
  • Compressors: Analog mode: Release Hold added.
  • Compressors: Analog mode: Progressive Release now also supported for non-constant speeds.
  • Bass clipper: Added new mode for much fuller, rounder, "angry" sounding bass.
  • Bass clipper: Added limiter for each generated harmonic separately.
  • Immersive Bass: Added limiter for each generated harmonic separately.
  • Multiband compressors: Added "soft clipper" mode, sounds more natural and dynamic, less agressive.
  • Compressors: Analog mode: RMS-based limiters affected band linking, solved.
  • Reduced red flashing of output meters in Ignore high frequencies mode.
  • CPU load settings added to protect against "insane" presets.
  • Compressors: Analog mode: Reduced CPU load for Peak mode when using dynamic speeds depending on CPU settings.
  • Low latency monitoring processing: Added half-HQ mode for lower CPU usage.
  • Natural Dynamics: Added compensate slope steepness setting (same as in Multiband 1 and 2).
  • GUI: License overview page didn't show The BIMP.
  • Command line version: Phase Delay wasn't taken into account when calculating the processing delay, causing time shifts in the output.
  • Command line version: "low latency" mode added for streaming providers that want to combine audio with video, see -l (or --lowlatency) option.
  • Streaming metadata: Remove trailing newline characters when reading from file.
  • Bug fix: Raspberry Pi version could crash.
  • Bug fix: Streaming metadata: Reading from file could fail if the "read upto" point was empty.
  • Bug fix: Streaming metadata: Reading from file could cause exceptions.
  • Bug fix: Streaming metadata: "Song" update from file looked at the Artist checkbox in the GUI.
  • Bug fix: "Ignore high frequencies" did not work properly anymore in the last releases, solved, reduces CPU load.
  • Bug fix: Web interface had an off-by-1 error in the recent presets list.
  • Bug fix: Web interface no longer attempts to change a setting if it's read-only.
  • Updated presets.
  • Perfect Declipper: Updated GUI to be able to release a new version.
  • MicroMPX: Pi version looked for libsndfile.so which is no longer present in some Linux images, now looks for libsndfile.so.1.
  • STX: Initial firmware version with touchscreen support pre-released.
Note: There is also a new version of Perfect Declipper, but before I upload that to the declipper site, since it hasn't been built and tested in a long time, I'm posting the binaries here:
REMOVED - they crashed
 Post subject: Re: Stereo Tool 9.50
PostPosted: Wed May 13, 2020 3:00 pm
On the declipper 32-bit vst, I launched it (inside BreakawayOne) and went through the tabs, saw that delossifier was inactive, I enabled it and got this error. It crashed the whole VST plugin.
PostPosted: Wed May 13, 2020 3:07 pm
I tried this and got the same result. Here's my error message:
Also, I forgot to comment out Stereo Tool when initially launching the BreakawayOne vst host (having both VSTs enabled), and it resulted in a constant popping as if both plugins were using the same buffer or something? I am able to run them both simultaneously just fine if I use the beta vst_declipper_302 posted a few ST versions ago. Seems to happen once the Declipper or ND is enabled.--edit: ok it went away after I raised the number of threads.
edit: Also the release date is listed as April 13 2020 on the download page :)
PostPosted: Wed May 13, 2020 4:16 pm
Ok I removed the Declipper downloads. Cause found though, so the next build will be ok. :(
Also updated the download page, thanks :) I guess I don't just not know what day it is anymore but not even what month.
PostPosted: Wed May 13, 2020 5:13 pm
And year is 2020. and taskbar icon is still bugged. (bypass)
PostPosted: Wed May 13, 2020 5:53 pm
Let's hope that new GUI comes very soon!
PostPosted: Wed May 13, 2020 6:25 pm
I imagine green..
PostPosted: Wed May 13, 2020 10:47 pm
Perfect Declipper: Attempt #2:
DSP: https://www.stereotool.com/download/dsp ... taller.exe
VST 32 bit: https://www.stereotool.com/download/vst ... lipper.dll
VST 64 bit: https://www.stereotool.com/download/vst ... per_64.dll
No changes that affect non-Declipper builds so if this one works I can still release it together with ST V9.50.
PostPosted: Wed May 13, 2020 11:16 pm
No crashes this time. But still that initial window size bug where the screen pops up large, but the program is only filling a small section of it. Can be fixed by re-sizing the window.
Otherwise, it's working fine. (Again, 32-bit VST inside BreakawayOne)
PostPosted: Wed May 13, 2020 11:44 pm
Apparently there is some issue with new version 9.50.
If no audio on input, meter on clipper shows huge activity.
Edit: it's happening on Dutch Chocolate Moose preset
