| Site Admin |
Latest version - Beta 021 (May 9 2020)
The biggest audio changes:
- Release Hold for constant speeds added
- Bass clipper filtering added. The idea here is that by limiting the harmonics that can be generated, you can push the bass clipper much harder without sounding bad, resulting in more constant bass AND a cleaner sound.
Downloads
Changes/bugfixes
- Maybe remove release hold in peak mode? -> No
- Natural Dynamics compensate slope steepness setting
- Enable 2nd stage bass clipper in Asymptotic mode, and make it possible to do the filtering before or after
- STX fix warning for PEQ
TODO's
- STX set final fps value
- Update DCM preset
- Streaming: Remove trailing newline characters when reading from file
- Update presets
- RELEASE
- Boogaard
- pens
- Disable gates when switching presets
- Added proper ShoutCast support (it was possible to use ShoutCast before but you had to fill in some things differently.)
- MicroMPX: Removed rate limiter on/off swtich. There's no good reason to ever turn it off.
- WatchCat: Use taglib1, which should support all ID3 text fields.
- STX: Upload preset was hardcoded to go to 172.22.16.101 in 9.50.
- STX: UECP settings missing
- STX: MB and AGC meters were wider in touchscreen interface, and had a scrollbar due to that.
- STX: Output spectrum added
- STX: Switching AES/EBU between 44.1/48 and 176.4/192 doesn't always work, requires a reboot.
- STX: RDS: EON, UECP and MONITORING missing.
- STX: Shorten names, remove unnecessary duplicates.
- STX: Metadata, Visible data, Traffic info, Alternative frequencies, Packet order, EON, UECP, Monitoring
- STX: Re-enable ACR, including saving on/off.
- STX: Web interface: Bug fix: Title sometimes shown in wrong location.
- STX: Add ACR to web interface
- SST: Multiple instances BUSY
- Stereo Tool: Multiple instances
- Website
- Disable stereo widening when detecting low bitrate MP3s
- Make final clipper (at least partially) do what Bass Clipper does, with harmonics control and Asymptotic mode?
- Add a checkbox under Delossifier that makes Absolute Highs fix the highs.
- STX output waveform not visible
- STX: Verify high frequency tilt behavior
- VST3 new NAN issue - waiting for CPU info (doesn't happen here).
- Check Stokkemask Use Area 100% does something at input level around -80 dB.
- Russian/Bulgarian translations don't work on 4K displays!
- STX: Create built-in presets. Initial set added
- Put Declipper presets in ST. Selecting one with "APPLY" overrules all existing settings.
- Linux Jack 64 9.37 on Debian 9, stereotool shows once in main cable connector twice in the "patch pannel" is this intended behaviour? If so what is the difference?
- Improve Advanced Limiter shape (Bojcha)
- BS412 bug: For Quality > 100, the compressors are off by a few dB (probably 1.5x or 2/3rds).
- Classical music preset THU
- How to synchronize HD? THU
- Test Framework? BUSY
- Try immediate release combined with release hold?
- Measure HifiBerry stereo separation -> Improved from 35 to 55 dB. Make RC work with Ignore high frequencies -> Later
- AGC classical music settings
- Loudness project
- Complaint: All (Normal, LL) outputs in Linux go to FM
- Tom aan de Stegge remarks email 30 september 20:23 - change many defaults
- Support rewindowing with different Quality/Size settings. Will give better HPF performance and make lower CPU load possible, and PPM patch points.
- Linux command line version with AES67 input so output can be streamed - seems to be useful... Other options (run a script for the output) might be easier.
- Finish 9 - final uMPX file name issue -> In next 9 update.
- Figure out how to display NMEA/pulse status in GUI. -> Waveform and jitter-view for pulse detection in detail view, GPS in stream, NMEA data, NMEA readable, Pulse detected flags.
- PhoneBooster make multi-threaded if needed (it probably is, esp. for Pi)
- PhoneBooster make Pi version
- Add something to get now playing content from file (but: first figure out how, could be via a separate program or something).
- Streaming output can hang - calls probably need to be moved to a separate thread. ???
- MicroMPX needs exception handling, just in case.
- WatchCat replace files instead of placing them elsewhere. For playout systems.
- WatchCat add CMD /C
- Thimeo School
- ABDP remove stuff that's no longer needed? BUSY for low CPU
- Optimize ABDP
- Input and output gain for command line version (like for sound card)
- Dynamic adjustment of priorities
- Sooth effect
- Crash ProppFrexx
- Update Omnia.SST presets
- AES67: Add WheatNet
- Create file when input fails
- Installer: Make installer aware of programs like MediaMonkey, AIMP, .....
- HD delay
- Document JSON interface
- Documentation: "Processing" page contains all kinds of BS412 info - why?
- Declipper L/R noise
- Declipper handle resampled audio better (upsample, find oversampling spikes, then detect based on what remains)
- Console version: Read sample rate and bit size from WAV header
- # bands selections should allow option to insert a band instead. Or ask what to do when you change it.
- AES67 thread affinities and priorities
- Add resampler
OLD VERSIONS
Latest version - Beta 020 (May 8 2020)
Downloads
Changes/bugfixes
- Added "soft clipper" mode to MB1 and MB2, seems to sound more natural and dynamic, more limiter-like
- Reported streaming crash both VLC and Internal? Issue found, to be tested
Latest version - Beta 019 (May 6 2020)
Downloads
Changes/bugfixes
- Streaming: "Song" doesn't get updated from file - looked at the wrong checkbox in the GUI.
- Check intermediate strength slider values for Immersive Bass harmonics filter.
- Immersive Bass harmonics filter cleanup filter was actually causing artifacts, should work much better now.
Latest version - Beta 018 (May 5 2020)
Downloads
Changes/bugfixes
- Off-by-1 error in web interface recent presets - Caused by an already existing error in the JavaScript code combined with the new websockets
- Added Immersive Bass harmonics filter cleanup filter
- Remove not needed parts from harmonics cleanup filter for performance
- Fix NAN issue in Immersive Bass harmonics cleanup (BETA017)
- Fix DCM preset filter values (broken due to enum value changes)
- Update version number to 9.50
Latest version - Beta 016 (May 2 2020)
Downloads
Changes/bugfixes
- Implement rest of Progressive Release
- Check if the cleanup setting doesn't make the sound worse, move the setting to Extreme Tweaker for testing only
- Make "Configurable" bass cleanup filter default, clarify the difference by making the switch a pulldown
- Figure out good default values for bass cleanup filter
Latest version - Beta 015 (May 1 2020)
Downloads
Changes/bugfixes
- Try to improve Bass Cleanup at Quality 100% - "Remove artifacts" setting added to get feedback, once we know this setting doesn't damage anything we'll remove it.
- Bass Clipper: Add Strength slider, 0% = off, 50% is perform ^.5 of what we calculated, 100% = full.
- Bass clipper: Add overall threshold offset slider
Latest version - Beta 014 (April 30 2020)
Downloads
Changes/bugfixes
- Add filtering to new bass clipper mode? Initial version ready
- Added parameters per harmonic for bass cleanup flter
- Added pre-ringing filter for bass cleanup flter
- Added Release Hold fox constant (maximum) speeds
- Command line version delay seems to be wrong, no preset. - Phase Delay wasn't taken into account because a call was missing
- Command line version "low latency" mode added for streaming providers that want to combine audio with video, see -l (or --lowlatency) option.
Latest version - Beta 011 (April 26 2020)
Downloads
Changes/bugfixes
- Show The BIMP in license overview
- Fix bug: Translation files did not work
- STX: Changed fps from 5 to 4.5
- Update DCM preset (much better highs)
- New bass clipper mode
Latest version - Beta 009 (April 24 2020)
Downloads
Changes/bugfixes
- Release hold added
- "Ignore high frequencies" did not work properly anymore (for a while already)
- Reduce CPU load as tried at IBC, at least for STX
- "No heavy CPU processing": Change the behavior to a step lower for Peak mode in "sane" mode.
- Low latency half-HQ mode?
- RMS-based limiter in band 4 affects band linking to band 5
- Red flashing in Ignore high frequencies mode -> Increased SetSensitive from 2% to 2.5%.
- Check changing of un-editable settings from Server.cpp (compares values and triggers a repaint with wrong values in native GUI)
- Declipper GUI bugs
- MicroMPX on Pi: libsndfile does not work on our image? - Fixed, but needs to be tested
- Pi version MicroMPX build (Model)
- Pi version Stereo Tool crashes
- STX buffer size displays
- STX debug settings page
- STX webinterface make latency settings easier, maybe add latency? And add screen sleep time setting. Verify that latency can be set properly, and change texts (4x per day is NOT true anymore)
- STX add warning if latency is too low
- STX reboot/update buttons on extra page
- STX fix crashes etc
- STX: Make front panel PJSON file
- STX: Make front screen interface
- STX: Adjust ranges of band mix, output level etc to max 6 dB. Say -3 to +3 dB. For other settings check ranges in existing presets, also for attack/release speeds etc.
- STX: Lock CPU usage (should be easy), and maybe also latency?
- PhoneBooster: Wrong icon shown in executable
- PhoneBooster improvement. Add maximum.
- PhoneBooster add auto EQ/compressors?
- PhoneBooster: Fix AGC display (right 2 bars need to disappear)
- PhoneBooster: Add new settings
- PhoneBooster: Add presets, and standard neutral preset
- PhoneBooster: Why is singleband compression invisible?
- PhoneBooster: Fix start bar SST icon Mathijs
- PhoneBooster: License
- PhoneBooster: Fix tray icon
