 Post subject: uMPX over LAN
PostPosted: Sun Apr 19, 2020 7:36 pm
Hello, can you send an uMPX signal through some server? icecast, shoutcast etc. Only encoder -> decoder inside the LAN.
Because looking at this page
https://jeroen580.wixsite.com/micrompx
at the bottom are the streams ip addresses.
I know that there is PI3b (or PI4) in the decoder, why such restraint from uMPX works only on a LAN. Is buying a VPN with a min 10MB / s connection so that the stream does not stop and error correction.
 Post subject: Re: uMPX over LAN
PostPosted: Mon Apr 20, 2020 9:46 am
I don't fully understand your question. The hardware device you link to is a third-party device, it is not ours. We currently only sell µMPX as software. It can stream over the internet or on your local network. Enabling error correction will very likely be necessary when streaming over the internet. Putting a server in between would not help IMHO.
