PostPosted: Mon Dec 20, 2010 12:14 am
When enabling FM mode/direct to sound card mode a new graph appears to the right of the oscilloscope.
What is this? What is it showing? How do I read it?
PostPosted: Mon Dec 20, 2010 10:49 pm
Hi Gtxx,
This is a spectrogram (frequency (hor) vs. amplitude (v)) of what's being sent to the sound card.
What you see is:
- Left: The normal signal
- Single spike: FM Stereo pilot tone
- Then you see the stereo signal
- Finally, the RDS signal
PostPosted: Mon Dec 20, 2010 11:41 pm
It looks cool lol but since I'm not transmitting I have no use for it.
Would an option to turn it off be possible?
PostPosted: Tue Dec 21, 2010 1:57 am
No... But why do you use the FM options if you're not broadcasting on FM? The sound quality is better without it... And you shouldn't NEED Direct Sound Card access...
PostPosted: Tue Dec 21, 2010 2:07 am
I'm using BA live and rather than route through BA again I have ST output direct to the card.
I send unprocessed audio to BA's line 2 which I use as input for winamp when running milkdrop.
Weird setup but it works! :)
I notice a difference in the clarity of high freqs when using direct to sound card than routing through winamp. <- thats when I used to use ST only for winamp.
I was just suggesting something :P I have no issue, it doesn't affect cpu usage to my knowledge.
