PostPosted: Tue Mar 24, 2020 1:14 am
Hi Hans.
On the new 9.40, when I do a "Save All Settings (export)", if I have set both the AGC and Singleband "start attack immediately" to 100%, it saves as it should. However, when I close and reopen ST, the previous setting of "start attack immediately" goes back to zero. It doesn't "remember" the previous settings. I need to reload the saved preset to get "start attack immediately" back. Is this a bug? Or just something that is supposed to occur?
Ted Alexander
(retired from Telos, but working at a small radio station)
PostPosted: Tue Mar 24, 2020 10:18 am
Hi Ted,
I just tried it here and they are saved and loaded properly when closing re-opening on my end. Could it be that something else is wrong and no settings at all are being saved? Maybe some rights issue?
PostPosted: Wed Mar 25, 2020 10:44 pm
More details:
The setting (Save all settings(export) does work. However, when I close an instance of ST, then reopen it for the next file, the setting doesn't appear to carry over. All the other settings do carry over. To get the setting to function on the reopened file, I have to reload the preset I was using previously. Do my words make any sense? :)
