PostPosted: Tue Jun 03, 2008 3:39 am
Stereo Tool 3.12 is available - as a Winamp plugin, a stand alone version and a command line version. See http://www.stereotool.com/download/ .
Changes since 3.11:
- Changing Stereo Tool values from within external scripts is possible (for example SAM broadcaster scripts: Change a setting for a certain type of content)
- Minor bug fix which you should not notice anyway.
If you don't need the external scripts, there's no need to upgrade from 3.11.
I'm still interested in whether the stand alone version works on all PCs... So if you are using it and it works (or if it doesn't), please post it here.
Hans
____
