I started with a specific preset (don't remember which one anymore) and I went from there. I admit it sounds better with some songs than with others. Let me add that this has been tested with Hip-Hop, R&B and some dance/electronic music. Opinions and suggestions are welcome!
[Common]
Pre amplifier=10
Post amplifier=0.930000007
Extra loudness=2.5
Extra loudness - Allow extra highs (advanced)=0
Extra loudness - Punchy=-0.75
Extra loudness - Max Punch peak=0.75
Extra loudness - Deep bass protection - Value=0.638750076
Bass protection - Enabled=1
Bass protection - Two steps=0
Bass protection - Clip level=100.900001526
Bass protection - Deep bass boost=0
Bass protection - Raise clip level if highs get above=153.130004883
Bass protection - Maximum clip level raise=36.040000916
Hard limit output=1
[Noise Gate]
Enabled=0
Difference=0
Noise level=1
Relative noise gate level - Band 4=1
Relative noise gate level - Band 5=1
Relative noise gate level - Band 6=1
Relative noise gate level - Band 7=1
[Singleband Compressor]
Enabled=0
Difference=0
Maximum volume=1.5
Attack speed=0.000149978
Decay speed=0.01500234
Above Top Limiter=0
[Pre Compressor]
Enabled=1
Maximum volume - Band 1=35000
Attack speed - Band 1=0.000005001
Attack speed - Band 3=0.000005001
Decay speed - Band 1=0.000249943
Decay speed - Band 3=0.000249943
Dual band=1
Third band=1
Relative expected volume of highs=0.649999976
Relative maximum volume of highs=3
Relative maximum volume of very highs=0.330000013
Remove remaining peaks above (relative to maximum volume)=1
Enable smoothing=0
Smoothing time=0
Gating level=1000000
Use ITU-BS.1770=0
Channel separation=0.300000012
[Multiband Compressor]
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band -1=2370
Maximum volume - Band 0=3050
Maximum volume - Band 1=3390
Maximum volume - Band 2=3560
Maximum volume - Band 3=2030
Maximum volume - Band 4=2200
Maximum volume - Band 5=2710
Maximum volume - Band 6=2030
Maximum volume - Band 7=2540
Maximum volume - Band 8=1690
Attack speeds linked=0
Attack speed - Band -1=0.000019993
Attack speed - Band 0=0.000019993
Attack speed - Band 1=0.000019993
Attack speed - Band 2=0.000015691
Attack speed - Band 3=0.000015691
Attack speed - Band 4=0.000015691
Attack speed - Band 5=0.000015691
Attack speed - Band 6=0.000015691
Attack speed - Band 7=0.000015691
Attack speed - Band 8=0.000015691
Decay speeds linked=1
Decay speed - Band -1=0.000139355
Decay speed - Band 0=0.000139355
Decay speed - Band 1=0.000139355
Decay speed - Band 2=0.000139355
Decay speed - Band 3=0.000139355
Decay speed - Band 4=0.000139355
Decay speed - Band 5=0.000139355
Decay speed - Band 6=0.000139355
Decay speed - Band 7=0.000139355
Decay speed - Band 8=0.000139355
Above Top Limiter=1
Clipping enabled=1
Postprocessing enabled=1
Relative clip position - Band -1=-1
Relative clip position - Band 0=-1
Relative clip position - Band 1=-1
Relative clip position - Band 2=1
Relative clip position - Band 3=1
Relative clip position - Band 4=1
Relative clip position - Band 5=0.65289247
Relative clip position - Band 6=0.503759503
Relative clip position - Band 7=0.388888836
Relative clip position - Band 8=0.408450603
Final limiter value=1
Final limiter decay speed=0.999000013
Final limiter clipping=0.204819322
Equalizer enabled=1
Equalizer position - Band -1=1.247190952
Equalizer position - Band 0=1
Equalizer position - Band 1=0.709401608
Equalizer position - Band 2=1
Equalizer position - Band 3=1.56410265
Equalizer position - Band 4=2.278688431
Equalizer position - Band 5=1.985074759
Equalizer position - Band 6=2.278688431
Equalizer position - Band 7=3
Equalizer position - Band 8=2.278688431
[Stereo]
Enabled=2
Stereo AZIMUTH Enabled=0
Stereo Image Enabled=0
Stereo Boost Enabled=1
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=0
AZIMUTH change speed=0
Image phase amplifier=1
Image width amplifier=1
Extra phase shift=0
Mono or stereo only=0
Stereo Boost strength=5
Stereo Boost maximum amplification=3
Stereo Boost multiplier=1
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=0
Lowpass filter=15000
Highpass filter=20
[Bass Boost]
Enabled=0
Strength=1
End lowpass frequency of input filter=250
Start lowpass frequency of output filter=250
End lowpass frequency of output filter=350
Clip level=1.5
Preserve louder peaks=1
Difference=0
[Phase Rotator]
Enabled=0
Start frequency=700
Start speed=1400
Number of rotations=4
Smoothness=0.979999959
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1
Pre-limiter enabled=0
Pre-limiter relative volume=1.75
Reduced CPU processing=0
[FM Transmitter]
Enabled=1
Pre-emphasize=1
Pre-emphasis time=75
Output is pre-emphasized=0
Stereo encoder enabled=0
RDS encoder enabled=0
Pilot signal volume=9
RDS signal volume=4.5
FM overdrive volume=1
RDS PS text=2s:STEREO/2s:TOOL/<1=1.5s,2..-2=2t,-1=1.5s:WWW.STEREOTOOL.COM/|\W"PLAYING %artist% - %title%        "/1s:\T2h\:\T02m\:\T02s/1s:\T2h\:\T02m\.\T02s/1s:\T2h\:\T02m\:\T02s
RDS RadioText text=60s:Stereo Tool: Professional Audio Processing - http://www.stereotool.com/30s:Stereo Tool by Hans van Zutphen, 1999-2008 - http://www.stereotool.com
RDS PTY=0
RDS PI=65535
RDS Alternative frequency 1=0
RDS Alternative frequency 2=0
RDS Alternative frequency 3=0
RDS Alternative frequency 4=0
RDS Alternative frequency 5=0
RDS Alternative frequency 6=0
RDS Alternative frequency 7=0
RDS Alternative frequency 8=0
RDS Alternative frequency 9=0
RDS TP=0
RDS TA=0
RDS Music=0
RDS Artificial Head=0
RDS Compressed=0
RDS Dynamic PTY=0
RDS RadioText Enabled=0
RDS ClockTime Enabled=0
FM Transmitter Calibration - Phase shift 20 Hz=0.25
FM Transmitter Calibration - Phase shift 160 Hz=0.25
[Direct soundcard access]
Enabled=0
Volume=1
Buffer size=0.200000003
Send to Winamp=Nothing
ASIO Override channel 1=4
ASIO Override channel 2=5
[Low latency output]
Enabled=0
Volume=1
ASIO Override channel 1=2
ASIO Override channel 2=3
