 Post subject: StereoTool in VMix
PostPosted: Thu Feb 06, 2020 3:03 pm
Hello!
StereoTool is awesome! We use years in our projects and we always use sensational audio quality.
In recent times we have used the StereoTools plugin in OBS for livestream transmissions through the vst 2 version, working perfectly together with the audio received through cameras.
But now I have another project at hand which uses VMix to generate the transmission, it allows integration with vst3 audio plugins, I tested several that worked perfectly but StereoTools didn’t, it presents several errors, stops working, crashes the VMix.
Has anyone made use of StereoTools to handle audio in VMix, can you give any tips?
Thanks!
 Post subject: Re: StereoTool in VMix
PostPosted: Thu Feb 06, 2020 4:52 pm
Hello! I don't use vMix or any VST3 compatible software. However on the list of bug fixes in the Beta for 9.38, there is an entry for vMix and VST3:
Changes/bugfixes
  • VST3 plugin bug fix: NAN's in vMix solved! (Compiler bug)
As of this post, the links for the plugins on the beta page don't list the VST3s, but they do at least appear to be uploaded up to beta version 32.
https://www.stereotool.com/download/vst ... 8-032.vst3
Good luck!
EDIT: They are now on the 9.38 beta thread: viewtopic.php?f=14&t=27324
