 Post subject: JAZLER WITH STEREO TOOL
PostPosted: Wed Nov 24, 2010 10:29 am
Hi i like to now if S.T. works with Jazler as stand alone like winamp or sam ?
and if so , how can i do that ?
thanks !
Vanilla Radio
Vanilla Coffee & Lounge Bar Greece
manager.vanilla ( @ ) gmail . com
|| http://www.vanilla.gr || http://www.vanillaradio.com || http://www.vanilla-lounge.gr ||
PostPosted: Fri Nov 26, 2010 5:40 pm
Vanilla Radio
PostPosted: Fri Nov 26, 2010 9:24 pm
Sorry for not responding sooner.
I don't know the program, but looking at its website and Google it seems that it doesn't have plugin support.
That means that you'll have to 'capture' the output coming from it and feed that through Stereo Tool.
This can be done with a (not free) program called Virtual Audio Cable (VAC).
The setup would then be: Jazler -> VAC -> Stereo Tool -> sound card (for FM) or another VAC if you want to use the output from Stereo Tool somewhere else (for example for web streaming).
The difference with Winamp and SAM is that in those programs you can use the Winamp plugin, if you use VAC you'll need the stand alone version (or, alternatively, also the Windows plugin, and then configure Winamp to use line in as source).
