 Post subject: vst registering
PostPosted: Sun Nov 21, 2010 12:17 pm
Hi! Got license key, stand-alone version is working now, but when I try to use vst plugin in Adobe Audition annoying windows keep popping-up and some spoken ad is mixed into the music. What should I do??
 Post subject: Re: vst registering
PostPosted: Sun Nov 21, 2010 10:29 pm
Hi ganek2010,
Just to check:
- Did you register the VST plugin separately? (I don't mean buying a separate key, but did you enter it into the VST plugin as well as the stand alone plugin?)
- Can you check the file C:\Documents and Settings\your_login_name\vst_stereo_tool.ini ? This file should contain a line that starts with 'Registration key'.
- Please send me a PM or email with your registration name (or key, or the email address you used for registering) then I can check if I can see anything here.
PostPosted: Sat Apr 16, 2011 11:59 pm
well, i have same problem. ganek2010, has you solved this?
PostPosted: Mon Apr 18, 2011 8:09 pm
Heibert. Have you checked what I asked ganek?
Just realized: if this file exists and it does not contain your key, you could try deleting it and then re-registering.
PostPosted: Wed Apr 20, 2011 11:14 am
i have such file. i have key inside. it looks like ST unable to read from this file because of permissions or another security issues.
PostPosted: Fri May 20, 2011 2:09 pm
problem still actual! each time i start ST i need to re-enter key and settings.
PostPosted: Tue Sep 20, 2011 6:42 pm
hvz, still need your help. :cry:
each time i start audacity and select StereoTool in effects, i need to copy-paste key into it.
it works till i close audacity.
while audacity is open, i can use stereotool many times, key is keeps in stereotool register window.
but after audacity restart i need to re-enter key again.
file "C:\Documents and Settings\your_login_name\vst_stereo_tool.ini" exists and contains my key after i enter it in stereotool plugin.
it looks like next time stereotool starts, it unable to read it from this ini file, or something like this.
