PostPosted: Wed Dec 18, 2019 10:48 am
Hello Sirs.
Just bought a preset for my FM radio and I am absolutely satisfied with it.
I just want a little tweak. I want to turn the volume up a little bit. If I mess with the master gain, it just dont like it.
Is there any other way to turn up the volume for just 1-2db?
Thank you very much.
PostPosted: Wed Dec 18, 2019 9:08 pm
First i want to know who is selling presets for ST? I might consider to buy some.
PostPosted: Thu Dec 19, 2019 5:34 pm
You can try turning up the overall density of the multibands or adjusting the final clipper drive (loudness) a small bit each.
