 Post subject: Sound Card
PostPosted: Sat Sep 11, 2010 5:29 pm
I Need to now. I do live show thru a mixer and sound card went i switch the sound card from winamp to sound card the stereo tool look like is no working. can any body help me with this problem? Thank you
 Post subject: Re: Sound Card
PostPosted: Sun Sep 12, 2010 1:12 am
Hello Hoyprod,
Do you use Standalone version of Stereo Tool or DSP version - Winamp Plugin ?
If you use winamp player , then you should install Winamp DSP Plugin of StereoTool.
Installer: http://www.stereotool.com/download/dsp_ ... taller.exe
Instalation is simple and all should work immediately. When you don't need StereoTool in winamp Just enable "Bypass".
