PostPosted: Fri Sep 03, 2010 10:00 pm
is there anyway that you hans can make a simple auto volume control for my net book and for anyone else that may want to use it....as you know it must be low latency and you need to be able to select what sound in put you want to use e.g virtual audio cable ... im asking this because sterotool does not work well with notebook as the cpu is not all that powerful...and you end up with skipping a bad latency problems..
if you can make make something like that id be happy to send you a donation for your trouble.
all it has to be is an automatic volume control that goes up in low sound and goes down on loud sounds.
obviously with some small settings like milliseconds for volume up and down.
its basicly going to get used for youtube and videos and stuff.. it just needs to be not so demanding on the
cpu as you know the intel atom is not that much of a power house.
im on skype if you need to ask me about this in call.
AND KEEP GOING WITH STEREOTOOL IT ROCKS IM STILL USING IT EVERYDAY and will continue to do so ...
thanks hans.
