PostPosted: Tue Sep 10, 2019 9:07 pm
You know that MB1 is not INF:1 right?
PostPosted: Thu Sep 12, 2019 3:38 pm
10:1 are from the limiters/Multiband clippers not for multiband compression.
You can not change ratio on the 8100,even the newer Orban boxes.
Garbage in is Garbage out !
PostPosted: Fri Sep 13, 2019 5:49 pm
I'm testing your preset... these levels are ok?
https://fmfeeling.com
