PostPosted: Sat Aug 21, 2010 7:01 am
Hi, this is my first post..
Here's my stereo tool settings. Please leave your comment about my setting and, if possible, give me suggestion to make it better (sorry about my English).
[Common]
Pre amplifier=5
Post amplifier=1
Extra loudness=1
Extra loudness Maximum increase per step=1.340000033
Hard limit output=0
Downsample very high input sample rates to near 44.1 kHz=0
Process for low latency=0
Mode=Advanced
Extra loudness - Allow extra highs (advanced)=0
Extra loudness - Punchy=-0.75
Extra loudness - Max Punch peak=0.75
Extra loudness - Deep bass protection - Value=0.638750076
Bass protection - Enabled=1
Bass protection - Two steps=0
Bass protection - Clip level=140
Bass protection - Deep bass boost=0
Bass protection - Raise clip level if highs get above=150
Bass protection - Maximum clip level raise=35
[Noise Gate]
Enabled=1
Difference=0
Noise level=1
Relative noise gate level - Band 4=1
Relative noise gate level - Band 5=1
Relative noise gate level - Band 6=1
Relative noise gate level - Band 7=1
[Singleband Compressor]
Enabled=1
Difference=0
Maximum volume=1.5
Maximum value=24576
Attack speed=0.004095
Decay speed=0.044036549
Above Top Limiter=0.5
[Pre Compressor]
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band 1=35590
Maximum volume - Band 2=17800
Attack speed - Band 1=0.000040472
Attack speed - Band 2=0.000014625
Decay speed - Band 1=0.000139355
Decay speed - Band 2=0.00019322
Remove remaining loud peaks=1
Dual band=1
Relative expected volume of highs=0.649999976
Relative maximum volume of highs=2.5
Remove remaining peaks above (relative to maximum volume)=2
[Multiband Compressor]
Enabled=1
Difference=0
Delay enabled=0
Very high quality enabled=1
Maximum volume - Band -1=4580
Maximum volume - Band 0=5420
Maximum volume - Band 1=6780
Maximum volume - Band 2=7800
Maximum volume - Band 3=8640
Maximum volume - Band 4=8980
Maximum volume - Band 5=6780
Maximum volume - Band 6=5930
Maximum volume - Band 7=3900
Maximum volume - Band 8=2030
Attack speeds linked=1
Attack speed - Band -1=0.00044999
Attack speed - Band 0=0.00044999
Attack speed - Band 1=0.00044999
Attack speed - Band 2=0.00044999
Attack speed - Band 3=0.00044999
Attack speed - Band 4=0.00044999
Attack speed - Band 5=0.00044999
Attack speed - Band 6=0.00044999
Attack speed - Band 7=0.00044999
Attack speed - Band 8=0.00044999
Decay speeds linked=1
Decay speed - Band -1=0.000629348
Decay speed - Band 0=0.000629348
Decay speed - Band 1=0.000629348
Decay speed - Band 2=0.000629348
Decay speed - Band 3=0.000629348
Decay speed - Band 4=0.000629348
Decay speed - Band 5=0.000629348
Decay speed - Band 6=0.000629348
Decay speed - Band 7=0.000629348
Decay speed - Band 8=0.000629348
Above Top Limiter=1
Clipping enabled=1
Postprocessing enabled=0
Relative clip position - Band -1=1.985074759
Relative clip position - Band 0=1.777777672
Relative clip position - Band 1=1.985074759
Relative clip position - Band 2=1.777777672
Relative clip position - Band 3=1.985074759
Relative clip position - Band 4=2.278688431
Relative clip position - Band 5=1.777777672
Relative clip position - Band 6=1.56410265
Relative clip position - Band 7=1.247190952
Relative clip position - Band 8=1.247190952
Final limiter value=1
Final limiter decay speed=0.000707469
Final limiter clipping=20
Equalizer enabled=1
Equalizer position - Band -1=1.247190952
Equalizer position - Band 0=1
Equalizer position - Band 1=0.503759503
Equalizer position - Band 2=0.5625
Equalizer position - Band 3=1
Equalizer position - Band 4=1.127659559
Equalizer position - Band 5=1
Equalizer position - Band 6=1.127659559
Equalizer position - Band 7=0.886792541
Equalizer position - Band 8=1.56410265
[Stereo]
Enabled=3
Delay enabled=0
Difference=0
Center bass=1
AZIMUTH limit=0
AZIMUTH change speed=0
Image phase amplifier=2
Image phase amplifier maximum separation strength=30.000001907
Image width amplifier=1
Extra phase shift=0
Mono or stereo only=0
Stereo AZIMUTH Enabled=1
Stereo Image Enabled=1
Stereo Boost Enabled=0
Stereo Boost strength=1
Stereo Boost maximum amplification=3
Stereo Boost multiplier=1
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=1
Lowpass filter=20000
Highpass filter=0
[Final Pre-Limiter]
Enabled=1
Difference=0
Pre-amp=1.000255942
Response time=0.100000001
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1
Response time=0.025
Pre-limiter enabled=1
Pre-limiter relative volume=1.75
Reduced CPU processing=0
[FM Transmitter]
Enabled=0
Pre-emphasize=0
Pre-emphasis time=50
Output is pre-emphasized=0
Stereo encoder enabled=0
RDS encoder enabled=0
Pilot signal volume=9
RDS signal volume=4.5
FM overdrive volume=1
FM overdrive Loudness or Quality=0.5
RDS PS text=2s:STEREO/2s:TOOL/<1=1.5s,2..-2=2t,-1=1.5s:WWW.STEREOTOOL.COM
RDS RadioText text=60s:Stereo Tool: Professional Audio Processing - http://www.stereotool.com/30s:Stereo Tool by Hans van Zutphen, 1999-2008 - http://www.stereotool.com
RDS PTY=0
RDS PI=65535
RDS Alternative frequency 1=0
RDS Alternative frequency 2=0
RDS Alternative frequency 3=0
RDS Alternative frequency 4=0
RDS Alternative frequency 5=0
RDS Alternative frequency 6=0
RDS Alternative frequency 7=0
RDS Alternative frequency 8=0
RDS Alternative frequency 9=0
RDS TP=0
RDS TA=0
RDS Music=1
RDS Artificial Head=0
RDS Compressed=1
RDS Dynamic PTY=0
RDS RadioText Enabled=1
RDS ClockTime Enabled=1
[Direct soundcard access]
Enabled=0
Device ID=Realtek AC97 Audio
Volume=1
Buffer size=1
Send to Winamp=Nothing
ASIO Override channel 1=4
ASIO Override channel 2=5
[Low latency output]
Enabled=0
Volume=1
Buffer size=0.109999999
ASIO Override channel 1=2
ASIO Override channel 2=3
[Bass Boost]
Enabled=1
Strength=1
Start lowpass frequency of input filter=20
End lowpass frequency of input filter=250
Start lowpass frequency of output filter=250
End lowpass frequency of output filter=350
Clip level=1.5
Preserve louder peaks=1
Difference=0
[Phase Rotator]
Enabled=0
Start frequency=700
Start speed=1400
Number of rotations=4
Smoothness=0.979999959
latest.rar [2.2 KiB]
Downloaded 690 times
