PostPosted: Mon Aug 05, 2019 2:48 pm
After updating to version 9.34, the scheduler seems not to recognise changed config files.
Kind regards,
Arkadas
PostPosted: Wed Aug 07, 2019 10:17 am
Rolled back to version 9.23 and scheduling via file polling works again.
upgraded to 9.34 and broken again.
So bug confirmed.
kind regards,
Arkadas
PostPosted: Fri Aug 16, 2019 2:35 pm
Confirmed and fixed. It looks like we broke it when we added the new (time based) scheduler.
The next release (9.35) will work again, and the next beta (after 013) too.
PostPosted: Sun Aug 18, 2019 11:36 pm
Thanks!
we use it specially for the classical music hours.
kind regards,
Arkadas
PostPosted: Fri Aug 30, 2019 11:55 pm
Sorry to bother again, but sadly in BETA935-019 the scheduler file polling seems still to be broken
In version 9.23 the scheduler works. rolled back again.
kind regards,
Arkadas
PostPosted: Fri Sep 13, 2019 1:08 pm
also in the latest release 9.35, the scheduler via file polling (poll STS) is broken.
kind regards,
Arkadas
PostPosted: Sat Sep 21, 2019 7:19 pm
I am also having problems with the scheduler. In v9.35 it recognises changes to e.g. Natual Dynamics and other processing settings, but sound card settings are ignored. Sound card settings could be changed with file polling in v9.23.
I really hope this can be fixed since we use the scheduler to switch between sound card inputs.
PostPosted: Tue Sep 24, 2019 12:00 am
While using the Scheduler Polling feature, I have noticed that it doesn't engage correctly until the Time Schedule Enabled switch is turned on, then back off again. It appears to be a state initialization problem? Perhaps related?
Great Hits and More!
http://RadioDAVE.US
PostPosted: Wed Sep 25, 2019 3:48 pm
confirmed!
Kind regards,
Arkadas
