 Post subject: μMPX Decoder player
PostPosted: Thu Jul 25, 2019 8:14 pm
One question:
does backup player in μMPX decoder goes back to start, once the backup file is played till the end?
Thnx
 Post subject: Re: μMPX Decoder player
PostPosted: Fri Jul 26, 2019 12:39 pm
Yes, it loops. The new decoder also has a setting to make it rewind after it has not been played for a set amount of time (e.g. rewind after one hour of stable connection).
PostPosted: Sat Jul 27, 2019 1:01 am
Thnx!
Do you also know what this type of error means: Could not subscribe to multicast address: The requested address is not valid in its context.
(10049)
PostPosted: Mon Jul 29, 2019 9:18 am
Are you trying to use multicast? If not, leave that field empty in the decoder. There's no need to enter IP addresses in the decoder unless you're using multicast.
PostPosted: Wed Jul 31, 2019 5:29 pm
Yes I run multicast.
PostPosted: Wed Jul 31, 2019 5:59 pm
So, is the address a multicast address? I did a quick Google for this error and found that you might get this if the address isn't in the range 224.0.0.0-239.255.255.255.
PostPosted: Thu Aug 01, 2019 4:17 pm
Hans, yes, that's correct. it's not.
It's static ip from internet provider.
PostPosted: Fri Aug 02, 2019 12:24 pm
I don't think you can do multicast over internet without using tunnels and other stuff.
PostPosted: Sat Aug 03, 2019 10:48 am
Thank you. I think that is OK then.
