PostPosted: Fri Jul 12, 2019 10:00 pm
hello is it possible to use the DSP plug in version of StereoTool with RadioDJ ?
On the download side of StereoTool
it is written that it is compatible with RadioDJ , but when I download it to my computer where RadioDJ is installed
he doesn't find it and nothing happens.
can you tell me if it's possible and how to proceed
Thank You
PostPosted: Tue Jul 16, 2019 3:56 pm
DSP (Winamp) version only works with the DSP plugin, and that is only working for Radio DJ versions before version 2.
So either use an older version, or take a different approach (i.e. standalone Stereotool with VAC, encoder with VST possibilities)
PostPosted: Thu Jul 18, 2019 11:24 am
Ah, good catch. I've removed RadioDJ from the list on the download page.
