 Post subject: Stereo Tool 9.30/9.31
PostPosted: Fri May 10, 2019 9:33 am
Stereo Tool 9.31 is released!
Changes:
9.30:
  • Added MicroMPX 2. (Note: You need to update your decoders if you want to use MicroMPX 2).
  • Added preliminary AES67 input support.
  • Added preliminary native streaming support (without libVLC), for now only MP3 (via LAME 3.93.1 or 3.100) and ogg/Vorbis.
  • Added parameter scheduler with file name, times, day-of-weeks and dates.
  • AGC: Added 2nd band.
  • Auto EQ/Bass EQ: Added RMS size for more precise behavior.
  • Advanced Clipper: ABDP: Mid bass protection: Changed default to off. No longer needed and people complained about "grainy" bass sound.
  • Compressors and AGC: Fixed "Relative release distance" behavior for FB^2 mode (release was too slow). Added "Legacy" setting for compatibility.
  • GUI: Improved slider mouse/cursor keys behavior, prefering round values.
  • GUI: Holding CTRL while scrolling or using arrow keys for sliders slows down the movement for more precise tweaking.
  • GUI: Holding SHIFT while scrolling or using arrow keys for sliders speeds up the movement for making big changes faster.
  • GUI: Changed (reduced) ranges and layout of sliders.
  • GUI: Displaying "off" in sliders instead of high or low values if the setting means no action.
  • GUI: All number of bands sliders replaced by pull-down menu's.
  • GUI: Fixed flashing display gates.
  • GUI: Flashing input meter.
  • GUI: Smooth movement down on input/output meters.
  • GUI: Synchronized input/output meters in stand alone version.
  • GUI: Simplified CPU threading configuration: Added dropdown to set up CPU's and affinities.
  • Bug fix: GUI: LLB meter showed wrong levels.
  • Bug fix: GUI: Legacy AGC: hide non-legacy settings.
  • Bug fix: GUI: Multiband 1 had 2 Behavior screens in Digital mode (one was for Analog).
  • Bug fix: Compressors: Fixed various issues in RMS size behavior which would result in too much or wrong movement.
  • Bug fix: Wrong value could be displayed (and used) briefly after startup in synchronization between sound cards.
  • Bug fix: Tilt correction: Added NAN recovery, just in case (no issues reported but it could fail).
  • Bug fix: GML plugin display did't open.
  • Bug fix: Rare exception message in Auto EQ in LQLL mode with 3 threads.
  • Stereo Tool installer: Don't open Explorer in installer.
  • Stereo Tool DSP installer: Now recognizes SAM, StationPlaylist, PlayoutONE, ...
  • Stereo Tool DSP installer: Didn't find new Winamp 5.8. It should now find both the old and new Winamp versions.
  • OmniaSST: Updated web interface.
  • Updated presets.
  • MicroMPX: Version 2!
  • MicroMPX: Set encoder to V1 when upgrading from an older version and MicroMPX was turned on.
  • MicroMPX: Added reset interval for backup file (time to start at the beginning).
  • MicroMPX: Added demodulated output monitoring.
  • MicroMPX: Using separate bitrate settings for MicroMPX 1/2.
  • MicroMPX: Removed extra \n's in logging.
  • MicroMPX: Removed weird warnings that were sometimes shown on startup in Windows.
  • MicroMPX: Increase default rate limiter setting to 100 kbit, and enable by default in Stereo Tool/SST.
  • MicroMPX: Updated web interface (added version, several decoder settings).
  • MicroMPX: Bug fix: Encoder in Stereo Tool was sending pilot when stereo coding was disabled in some situations.
  • MicroMPX: Bug fix: Built-in version in Stereo Tool could crash when feeding only 1 channel (mono input file in plugin).
  • MicroMPX Node: Create separate 2-channel build.
  • MicroMPX Node: Set storage location and auto-save.
  • WatchCat: Bug fix: File in use behavior was wrong on Windows.
  • WatchCat: Bug fix: Move failed files to Failed was broken on Windows.
9.31:
  • Bug fix: Auto EQ RMS size was set to non-zero when loading older presets in 9.30, causing them to sound different.
  • Bug fix: Shift and Control keys did not work in MacOS GUI.
