PostPosted: Thu Jun 03, 2010 6:43 pm
HI again , i have make a clean instal nothing else from s.t. and jazler .
i have a clear sound only from jazler, when i run the s.t. i hear a noice tone from back of a music and the presets not working .
i try microsoft sound maper out from jazler and input of s.t. and i choice the one line out from maya with out asio , but nothing.
with this card but in other p.c. with xp everything is ok with s.t.
anyone ?? i also try it and with vista with the same resoults..nothing .
p.s.
i lost the drivers cd from esi and i download the drivers from the site http://download.esi-audio.com/?w=esi&p=14&g=1&l=en
but nothing else ,sould i find and asio ? if you now ? and from where ?
and if you now in win7 what card must to be as first ? on board or the maya ?
thanks in advance !!
Vanilla Radio
Vanilla Coffee & Lounge Bar Greece
manager.vanilla ( @ ) gmail . com
|| http://www.vanilla.gr || http://www.vanillaradio.com || http://www.vanilla-lounge.gr ||
PostPosted: Fri Jun 04, 2010 2:04 am
Do you have any idea if this is a driver problem or a Stereo Tool problem?
The ESI drivers are often pretty horrible - I still haven't managed to get them working properly on Vista64. Well, they work... But very often the driver chooses the wrong sound card frequency. And so far the only solution I've found for that is rebooting.
Or is it a Stereo Tool problem? If you play silence, do you see the sliders move? And the noise that you hear, is that a hiss, or maybe the RDS signal that is somehow downsampled in a very bad way? If you turn RDS and stereo coding off, is the noise gone then? If so, are the sample rates that the ESI control program reports correct?
