Post new topic  Reply to topic  [ 166 posts ]  Go to page 1 2 3 4 517 Next
 Post subject: Stereo Tool 9.24 BETA
PostPosted: Tue Mar 05, 2019 10:55 am
Latest version - Beta 031 (April 28 2019)
Downloads
Changes/bugfixes
  • Fixed reported crash in Auto EQ (Livewireaus)
  • Fixed reported crash when switching to Current AGC mode (in GUI)
  • Update preset Cerulean
  • RELEASED 9.30
TODO's
  • Bug fix: Auto EQ RMS size was set to 20 ms for presets that had no RMS size before, could affect Auto EQ levels too much.
  • Bug fix: New mouse behavior with control and shift on MacOS was broken.
  • Update presets Dutch Chocolate Moose, Cerulean
  • Verified peak compressor modes, seem to be identical to 9.23. Waiting for more feedback/example settings file...
  • RELEASE 9.31
  • MPX Node Encoder 2 channels 16 bit input
  • RMS-based limiter with ratio based on input
  • Optimize performance of resampler (combine channels) BUSY - Probably OK, WatchCat to be done
  • Check crackle in Immersive Bass
  • WatchCat crashes on Mac
  • L-R reverb
  • Crash ProppFrexx
  • Update Omnia.SST presets
  • AES67: Add WheatNet
  • Create file when input fails
  • Change clipper defaults (Dutch Chocolate Moose has some improvements that use the new features)
  • HD delay
  • Document JSON interface
  • Documentation: "Processing" page contains all kinds of BS412 info - why?
  • Declipper L/R noise
  • Add resampler
  • Regarding new slider behavior:
    • Double clicking the current position of the slider will open a dialog where you can manually enter a value.
Latest version - Beta 030 (April 27 2019)
Downloads
Changes/bugfixes
  • Check licenses (LGPL etc) in all about pages
  • Use dynamic linking for Libshout. Try to get rid of "strcasecmp" in Preprocessor defined
  • Check Matt's complaint about bass distortion with new bass clipper mode -> Un-deprecated and renamed setting, removed warning, changed default.
  • GUI: Changed the range of a lot of parameters to make more sense (-99 dB for a bass clipper is useless).
  • Update preset Dutch Chocolate Moose
Latest version - Beta 029 (April 26 2019)
Downloads
[*]Windows 32-bit standalone
[*]Windows 64-bit standalone
[*]VST2 32-bit
[*]VST2 64-bit
[*]Winamp DSP 32-bit
[*]Windows MicroMPX encoder
[*]Windows MicroMPX decoder
[*]ARM 32 bit MicroMPX encoder
[*]ARM 32 bit MicroMPX decoder
Changes/bugfixes
  • GML display won't open To be tested
  • Can we turn Legacy RRD off automatically when loading a preset that doesn't use FB^2 mode?
  • Composite bass clipper gets uninitialized data with certain settings -> Caused by modulator in SSB mode
  • Reported crash in 022 - Needs to be verified
  • Valgrind
  • Windows XP compatibility broken by AES67 code
Latest version - Beta 027 (April 20 2019)
Downloads
Changes/bugfixes
  • Added "Legacy relative release distance" to AGC and all compressors. Turn this OFF to get the correct RRD behavior when using FB^2 mode!
  • Changed RMS size behavior in AGC, Auto EQ and all compressors! Could cause levels to never be reached, that's solved now. Sound may be slightly different! (But probably nearly always better, more consistent, less pumping).
  • MicroMPX was sending pilot when stereo coding was disabled in some situations.
  • MicroMPX 2 now works upto 576 kbit/s (decoders need to be updated if you want to go above 512!).
  • MicroMPX feed() function from Stereo Tool could crash when feeding only 1 channel (mono input file in plugin).
Latest version - Beta 022 (April 5 2019)
Downloads
Changes/bugfixes
  • MicroMPX 2 table & bug @ 512 kbit WARNING, BREAKS COMPATIBILITY . So if you're using Version 2 mode (which was in beta anyway), you need to update the decoders as well.
  • AES67 add resubscribe -> Not needed, subscribe works even if the ethernet cable isn't connected at the moment of subscribing
  • AES67 wait for first packet on startup
  • Fixed another small Winamp installer issue (now looking at different registry key)
Latest version - Beta 019 (April 2 2019)
Downloads
[*]VST2 32-bit
[*]VST2 64-bit
Changes/bugfixes
  • Red for no signal AES67
  • Check AES67 restart behavior
  • AES67 input also for low latency signal
  • Update Cerulean preset
  • Set MicroMPX to mode 1 if it is turned on and no setting is available. Or show a warning?
  • MicroMPX demodulated output doesn't start de-emphasized
  • WatchCat move failed files to Failed broken on Windows.
  • Crash in MB1 Digital mode when going to Behavior display, and 2x Behavior visible.
  • AES67 NIC's were displayed incorrectly.
Latest version - Beta 018 (March 31 2019)
Downloads
Changes/bugfixes
  • AES67 doesn't return silence when there is no signal, hangs instead.
  • AES67: Add Dante
  • AES67: Support other sample rates (by manually choosing, for now).
  • AES67: add NIC selecton
  • DSP plugin installer didn't find new Winamp 5.8. It should now find both the old and new Winamp versions.
  • GUI: Pop-up for new mouse behavior (which should become default) when you seem to try to adjust a slider very precisely
  • GUI: Red flashing of input meters - Looks fine, expect in the situation where 2 inputs are combined. Input data is oversampled so that might cause more (correctly!) reported overshoots.
  • MicroMPX: Removed extra \n's in logging
  • MicroMPX: Removed weird warnings that were sometimes shown on startup in Windows
  • MicroMPX: Increase default rate limiter setting to 100 kbit, and enable by default in Stereo Tool/SST.
  • MicroMPX: Updated web interface (added version, several decoder settings)
  • OmniaSST: Updated web interface
  • Split Dutch Chocolate Moose into Smooth and Hot versions, changed some settings
Latest version - Beta 017 (March 28 2019)
Downloads
[*]Windows 64-bit standalone STILL 016, 64-bit build failed
[*]VST2 32-bit
[*]VST2 64-bit
Changes/bugfixes
  • Add preliminary AES67 input support (LiveWire only for now)
  • Streaming: Set output samplerate for LAME, remove setting for Vorbis (since the encoder used doens't support it and we have no time to write a resampler now)
  • CPU settings: Add mode with no affinities set
  • GUI: LLB meter showed wrong levels
  • GUI: Mouse click next to slider pos should jump there if far enough away
  • GUI: Legacy AGC hide non-legacy settings
  • Update presets: Breaking Dreams, Cerulean, Chocolate Moose
  • Fixed WatchCat file in use behavior after update
  • Check that license for MicroMPX works.
  • Set MicroMPX node build log file location
Latest version - Beta 016 (March 26 2019)
Downloads
Changes/bugfixes
  • Add something to set up CPU's
  • Use older LAME (3.93.1) which sounds much better
Latest version - Beta 013 (March 23 2019)
Downloads
Changes/bugfixes
  • Streaming: Added Name, Description, Genre, URL, Public settings
  • Stream Start() moved to separate thread to not interfere with normal I/O
  • Streaming sending of audio to encoder moved to separate thread to fix sound card buffer misbehaving
  • Fixed FM output level slider (made it a "precise" slider, no need to press control to precisely change it).
  • Added tilt NAN recovery, just in case (no issues reported but it could fail.)
  • MicroMPX: Fix 2-channel build
  • MicroMPX: Fix storage location and auto-save
Latest version - Beta 012 (March 21 2019)
Downloads
Changes/bugfixes
  • Flashing display gates
  • Flashing input meter
  • Smooth movement down on input/output meters
  • Synchronize input/output meters in stand alone version
  • Check reported VST crash in ProppFrexx - Probably fixed
Latest version - Beta 011 (March 20 2019)
Downloads
Changes/bugfixes
  • Added native streaming support (so without libVLC), for now only MP3 (via LAME) and Vorbis.
  • Installer: Don't open Explorer in installer
  • Installer: DSP installer must recognize SAM, StationPlaylist, PlayoutONE, ...
  • Don't allow above 0 dB broken
Latest version - Beta 009 (March 9 2019)
Downloads
Changes/bugfixes
  • Limit/Clip etc default values are too big, no problem if we display them as OFF.
  • Slider value always returned inside range now, to avoid weird mouse wheel/cursor key behavior at extremes.
  • DCM: IB level -9 dB, lowpass 80 Hz, MB2 attacks B1/2 to 75, 50. Hoogste 2 naar -15, 17, clip -.50, +1.00. Always clip deep bass below, dynamically reduce to 100%. MB1 limit +6, MB2 limit +4, clip +3. Sloppy at 200%. Highs clipping +6, Highs Priority +6.
  • Add something to set up scheduler
  • Move scheduler to separate thread!
  • Separate bitrate settings for MicroMPX 1/2
  • Make sure that new maximum values don't cause things to be turned on!
Latest version - Beta 008 (March 8 2019)
Downloads
Changes/bugfixes
  • Shift should snap on mouse movements
  • Snap to round values on sliders with big range when normally moving the mouse
  • # bands was not working for built-in presets (BETA007)
  • Limit/Clip etc default values are too big, no problem if we display them as OFF. -> Partially done
Latest version - Beta 007 (March 7 2019)
Downloads
Changes/bugfixes
  • Update slider behavior with logical step sizes and flat dB ranges
  • Holding CTRL while scrolling or using the arrow keys for sliding sliders will slow down the movement for more precise tweaking
  • Holding SHIFT while scrolling or using the arrow keys for sliding sliders will speed up the movement for making big changes faster
  • # bands selections are now drop-down menus
Latest version - Beta 006 (March 5 2019)
Downloads
Changes/bugfixes
  • Added toggle for improved mouse behavior - see below
  • This issue was reported: viewtopic.php?f=14&t=25882&p=58602#p58602
  • Try out if improved RMS behavior also possible for Auto EQ/Bass EQ? -> 1 value for all bands.
  • AGC 2 bands
  • Multiband lowest band can overreact with big RMS size
  • MicroMPX: Added MicroMPX 2! Warning, not compatible with MicroMPX 1 decoders (you need to update the decoders), and we have only started testing it last night
  • MicroMPX: Added reset interval for backup file
  • MicroMPX: Added demodulated audio monitoring
  • MicroMPX: Added GPS synchronization settings (incomplete, doesn't work yet)
About the new mouse behavior:
Slider behavior in Stereo Tool did not conform to how sliders usually work.
To sum up the changes that become enabled when "Old mouse behavior" is turned off in Configuration:
  • Clicking in the slider bar sets the slider to that position and allows dragging.
  • Clicking on the current position of the slider "grabs" the slider without moving it, and allows dragging.
  • Holding CTRL will significantly slow down the movement, allowing for much more precise tweaking. The same if you click the right mouse button while dragging.
PostPosted: Tue Mar 05, 2019 11:28 am
Hello Hans,
This is a suggestion, would it be possible to fix in the cursors, the numbers on the one hand and on the other hand the technical terms translated on 2 levels in the cursor, because in their movements the terms are often truncated.
PostPosted: Tue Mar 05, 2019 4:15 pm
Would it be an option to implement an "global" checkbox for easy/quick adjusting multiple bands at once?
So you can quickly move all the sliders of let's say the limiters in multiband 1 to a certain level an from there you can finetune it?
It was an option in "Sound Solution" software, where it was called "global".
Maybe adding a choice that all the current values adjust from where they are now, or matching them with the slider you're adjusting?
Next question:
Can you make mids and highs clipping in the Advanced Distortion Protection visible with 2 small meters?
Last question: In the processing page you can quick adjust the bass, mids and highs. But you can only adjust them by large jumps. Can these be somewhat smaller maybe? I know i can do it manually in the multibands but this would be easier :lol:
Greetings and keep up the good work!!
PostPosted: Thu Mar 07, 2019 12:34 am
BETA007 is available! Slider sensitivity has been updated for all sliders (if I didn't forget any).
PostPosted: Thu Mar 07, 2019 12:36 am
I hope that the new slider behavior (see latest upload) is already making this easier than it was. I am trying to avoid adding more settings to the interface than what's already there (which is already quite a lot). And thresholds for example can be changed by changing the drive/output level or density drive settings.
Next question:
Good idea... Yes.
The precision is 0.1 dB, that's not big? Am I missing something?
PostPosted: Fri Mar 08, 2019 10:51 pm
Hans, it might just be you haven't got to it yet, but the De-esser limit slider doesn't work in either new or old mouse behavior, you can have full on, full off or +7dB, it can't be adjusted to anything else.
PostPosted: Sat Mar 09, 2019 2:48 am
Ah! I missed that one. Fixed!
PostPosted: Sat Mar 09, 2019 12:31 pm
BETA009 is available.
PostPosted: Sat Mar 09, 2019 1:32 pm
where can I download micrompx 2?
PostPosted: Sat Mar 09, 2019 1:38 pm
Oops! I forgot to post them. Just added the Wndows executables, will add the Pi executables after the next build (I cancelled the latest Pi build so I don't have the most recent version).
