PostPosted: Wed Feb 20, 2019 8:57 am
I purchased like others via pay pal for 99 euros and no license. Perhaps it is not automated?
PostPosted: Wed Feb 20, 2019 11:09 am
Not yet, indeed.
PostPosted: Wed Feb 20, 2019 1:33 pm
Thank you, I’ll try to wait patiently! Eager to use without tags :)
PostPosted: Wed Feb 20, 2019 2:46 pm
I now have the license, but it seems to say it is registered, but shows not registered. Still hearing the beeps and tags. Ill see what others did to fix this an hopefully be on my way. Is there an FAQ for these matters?
PostPosted: Wed Feb 20, 2019 3:15 pm
I found this, but I do not see a directory with that file to manually add the key.
Ah! I received several complaints about entering the code in the VST version but so far none really explained why it went wrong - your description finally does!
There's a workaround:
- Close the VST plugin
- Find the file C:\Users\<username>\vst_stereo_tool.ini
- Open it and look for a line that starts with 'Registration key='
- Paste the key after that
- Open the VST plugin again. It should be registered now.
Based on your description, the VST host is sending updates of the text field which causes the changes to get lost somehow. That should (finally) help to fix it.
Question: Can you type texts normally in the RDS fields? (Configuration -> FM Transmitter -> RDS)?
PostPosted: Wed Feb 20, 2019 3:25 pm
Okay, I was able to click directly on the DLL and manually add. Perhaps a nice FAQ should be made to help others in this situation.
