 Post subject: M audio M track 2x2M
PostPosted: Sun Jan 27, 2019 10:45 pm
Hallo mede gebruikers!
Ik heb sinds gisteren de m track 2x2m van m audio in bezit. De sound is opzich goed, maar ik krijg mijn input level niet omlaag...
Als ik dus vanuit mijn mengtafel 0db uitstuur dan gaat hij vol in de clip, terwijl de gain potmeters helemaal dicht staan!
Ik ga dus geballanceerd in en uit (xlr in en Jack 6.3 uit)
In windows (10) onder geluidsinstellingen kan ik de input wel omlaag zetten maar er gebeurt niets...Het asio menutje stelt ook niets voor, je kunt alleen de sample rate aanpassen en de buffer size.
Is er iemand die hier meer van weet?
Ik zou er een filmpje van kunnen sturen op de whatsapp als je wenst...
Gr Kay
 Post subject: Re: M audio M track 2x2M
PostPosted: Mon Jan 28, 2019 12:29 am
How you connect mixer to card?
PostPosted: Mon Jan 28, 2019 12:31 am
Im going xlr out
PostPosted: Mon Jan 28, 2019 12:46 am
This will sound strange, only and safe way is to connect RCA's from mixer master output to XLR's soundcard.
That will give you nice headroom on soundcard' input and don't worry, sound will not be bad!
PostPosted: Mon Jan 28, 2019 12:56 am
Okay...thanks for your answer bojcha...but i dont agree 100% with you.
Why would you take the rca monitoring output instead of the head xlr output from the mixer?...
I nether see the difference, the problem is that the input goes way to loud! In my zalman hd160xt pc i have a marian trace alpha placed...which come with an software mixer so you can lower your gain. Then the problem is solved.
The m audio doesnt come with that.
My mixer is an d&r airmate mark 3 if you want to know...
PostPosted: Mon Jan 28, 2019 1:43 am
You need master RCA output on mixer.
RCA is usually around 0.7v (upt to 2volts) input/output and XLR is around 1.5v (up to 4volts) input/output. So In this way you feed 4v with 2v wich is translated in dB's around -8dB of headroom.
You can also do same with XLR to XLR but with speacial cables with resistors.
PostPosted: Mon Jan 28, 2019 5:48 am
Ok, i will try it.
Greets Kay
