Post new topic  Reply to topic  [ 143 posts ]  Go to page 1 2 3 4 515 Next
 Post subject: Stereo Tool 9.12 BETA
PostPosted: Fri Nov 02, 2018 1:00 am
Latest version - Beta 24 (Release Candidate 1)
Downloads
Changes/bugfixes
  • Pi build fails
  • Add "^2" mode to pre-bass clipper. Different shape, has less effect on higher frequencies.
  • Update Wes' preset
TODO's
  • (Since beta 3) Add a popup for buffer overrun/underrun (also for suspicion)
  • (Since beta 3) Add MagicRDS AF method B support
  • (Since beta 3) Automate generating MicroMPX licenses
  • (Since beta 3) Backup audio doesn't go to LQLL
  • (Since beta 3) Brian (NAB)
  • (Since beta 3) Cntrct IN
  • (Since beta 3) Declipper: Put startup in system tray back in Declipper (at least in the Winamp plugin version).
  • (Since beta 3) Fake stereo idea
  • (Since beta 3) Finish Kantar tests and integration
  • (Since beta 3) Linux multiple instances
  • (Since beta 3) Linux-version MicroMPX integration in ST.
  • (Since beta 3) Matrix stereo widener BUSY, problem with suddenly loud stereo (goes down in level, makes everything pump - badly). Try running L+R with a slower attack speed, if that doesn't sound good, remove it.
  • (Since beta 3) Noise in declipper issue
  • (Since beta 3) Pi 64 bit builds on the site
  • (Since beta 3) RDS: EON: Support for other type of AF frequencies?
  • (Since beta 3) Right-click tray icon bypass is bad
  • (Since beta 3) Show warning when using MME with wrong sample rate
  • (Since beta 3) Support for more than 32 ASIO channels
  • (Since beta 3) Test sound card
  • (Since beta 3) uMPX encoder/plugin: Sound card speed message
  • (Since beta 3) VST for DJB
  • (Since beta 4) AAX plugin
  • (Since beta 4) Glitch when turning Bypass off
  • (Since beta 4) MicroMPX: Add manual (how to setup)
  • (Since beta 5) 1024x600 screen misses VU meters
  • (Since beta 14) Can you please check Pre-Limiter used with Normal limit making some strange effect with thresh under 3-4dB at 64 bands or less.
  • (Since beta 10) Check new installer script
  • (Since beta 15) Clearer split between normal and advanced RDS features
  • (Since beta 15) Declipper cleanup L-R phase artifacts, maybe also width.
  • (Since beta 21) "Relative adjustment" too low warning
  • (Since beta 23) Check what to do with highs (Bojcha) - maybe next year? Dynamic highs clipping level might work. -> Waiting if needed first, maybe now.
  • (Since beta 24) Speed up start of attack/release? Compare new values with what we're doing, and increase them if the difference is big.
  • (Since beta 24) Fix Basstardizer which broke in 9.20
  • (Since beta 24) Check highs 5 kHz issue in clipper (?)
Older versions
Link to post: Version 023
Downloads
Changes/bugfixes
  • Add 2-stage bass clipper in advanced clipper
  • Maybe add 3rd stage to Advanced Clipper? Done, Extreme Tweaker mode and experimental only for now.
  • Check highs issue in Composite Clipper Done, needs different Leif's highs settings (200% instead of 400% seems reasonable).
  • Improve filtering in 2nd bass stage in Advanced Clipper -> No, split into 2 stages. Pre and post.
  • Hide AVX setting
  • Update Dutch Chocolate Moose preset
  • Update Cerulean preset
  • WatchCat on Mac doesn't work -> Installer issue, check before releasing
Link to post: Version 022
Downloads
Changes/bugfixes
  • Performance on Windows XP (potentially on all systems without AVX support) is back to normal.
  • Check Basstardizer DIFF mode -> Checked, works fine now, probably an issue with the optimization error in previous beta's
  • Add import/export of IB
  • Fix Mac build
  • WatchCat GUI glitch fixed
Link to post: Version 021
Downloads
Changes/bugfixes
  • Fixed AVX/SSE switch (compiler bug workaround) - works on older systems/OS's again.
    About 5% CPU load reduction on newer systems.
Link to post: Version 019
Downloads
Changes/bugfixes
  • Stereo Tool: All builds now run on a Pentium 3 :shock: - no separate builds needed anymore...
  • Stereo Tool/SST: Disable MicroMPX if there's not at least SSE2
  • Stereo Tool: Kill off old SSE builds
  • Remove SSE2 check from installers
  • Test MicroMPX performance with new gcc on pi - 2% improvement
Link to post: Version 018
Downloads
Changes/bugfixes
  • AVX2 support: Performance improvement on Intel Core i3/5/7 4000+ series when using Windows 7 SP1+/Windows 8/Windows 10
  • Stereo Tool: Measure effect of EstimateMath defines, try to remove - Not needed
  • Stereo Tool: Get rid of #ifdef SSE2 in OldSamples
  • Update Mathijs, Wes, Bojcha presets
Link to post: Version 017
Downloads
Changes/bugfixes
  • RDS: Add EON, via GUI and UECP
  • IB Hear function didn't work correctly if IB was moved
  • Fixed reported crash
  • Presets DCM and Cerulean, Magic Gold and Paul: Check BS412 levels. And update Cerulean to 1f
  • Update Wes' and Bojcha's preset
Link to post: Version 015
Downloads
Changes/bugfixes
  • Immersive Bass HPF output not working correctly
  • Immersive Bass HPF input for cleaner sound ?
    Difficult to do, doesn't appear to do a lot anyway.
  • Change Advanced Clipper for cleaner voices (less IMD). Very slightly higher CPU load.
  • Preset add Wes, Matt
  • Made Immersive Bass movable (before Auto EQ, before AGC, after AGC - before it was always before AGC).
Link to post: Version 014
Downloads
Changes/bugfixes
  • Is VST3 ok in vMIX after the latest build? - Should be, works here, and code is more logical.
  • Immersive bass: Removed protection to not add too much again. It didn't have much effect, caused artifacts, and different compressor settings can give a very similar effect.
  • Remove MicroMPX startup logging in Stereo Tool/SST if not running, and put log file in user directory.
  • Linux MicroMPX version (32 bit)
  • Linux MicroMPX version (64 bit)
Link to post: Version 013
Downloads
No downloads available.
Changes/bugfixes
  • Immersive bass: Protection to not add it if it's already there removed too much, now it's a slider.
    Value 1 = same as BETA012, value 10 = same as BETA011. Good range seems to be around 2-3.
    More testing needed.
  • Remove library MicroMPX startup logging
Link to post: Version 012
Downloads
Changes/bugfixes
  • What does the new Immersive Bass display show? Either remove it, or add it to bottom display as well.
  • Immersive bass: Added protection to not add it if it's already there (can be defeated, for now, for testing).
  • Updated Paul Thompson's Breaking Dreams Loud preset - now uses Immersive Bass.
Link to post: Version 011
Downloads
Changes/bugfixes
  • Finish Immersive Bass: Add better HPF, tilt, non-lossy adder,
    update name to Immersive Bass, updated presets.
  • RDS: Remove dynamic memory allocations when the PS/RT/PTYN strings are modified.
    Pre-allocate enough memory once.
  • RDS UECP: Add support for multiple UECP encoders with different port addresses.
  • RDS UECP: Add support for multiple site/encoder addresses.
  • Add Mathijs' new preset
Link to post: Version 010
Downloads
Changes/bugfixes
  • VST3 plugin doesn't work in vMIX - fixed something...
  • Added new bass filter (not yet finished)
Link to post: Version 007
Downloads
Changes/bugfixes
  • VST3 64 bit plugin fixed (32 is probably still broken)
  • RDS: UECP: Site and Encoder address were swapped. Fixed, not tested.
Link to post: Version 006
Downloads
Changes/bugfixes
  • CPU load 100% in web thread Linux?
  • No ASIO asserts in debug mode
  • Group 15B also send 4x on TA start (was only doing it on end).
  • Added odd/even harmonics selection in Basstardizer (was only odd before).
Link to post: Version 005
Downloads
Changes/bugfixes
  • Nicer input sound card open error handling (softer beeps, retrying and restarting added).
  • RDS: Add PIN to interface
  • VST3 plugin
Link to post: Version 004
Downloads
Changes/bugfixes
  • Volume display FM output seems wrong when streaming output is enabled with separate processing.
    Almost certainly only GUI issue.
  • Noise gate windows audible
  • Auto-select 192 kHz FM output sound card as default
  • No PIN EWS
  • Look at text alignment
  • Split RDS features in standard and advanced RDS (EON, AF method B, ECC, EWS, ODA - TMC etc)
Version 003
Downloads
Changes/bugfixes
  • RDS AF method B
  • RDS AF method B via UECP
    probably done but can't test it now.
  • No more white screen in generic plugin
    was caused by wrong #ifdef
  • I/O and BIMP no longer missing in web interface
PostPosted: Fri Nov 02, 2018 1:27 am
Stereo Tool 9.12 BETA003
  • RDS AF method B
  • RDS AF method B via UECP Probably done but can't test it now.
Thank you for this! Was waiting for RDS method B.
Now I need to find some time to test it :)
PostPosted: Fri Nov 02, 2018 3:22 am
All text in gui aligned to left on meters and boxes with some errors at brightness 93. Not all skins.
edit: 'center text' wooh
PostPosted: Fri Nov 02, 2018 3:46 am
What's with to-do list where was option to hide non-used filters/meters?
PostPosted: Mon Nov 05, 2018 4:15 pm
Method B through UECP doesn't work.
However - method B works in ST, but I don't think that it works right.
PostPosted: Mon Nov 05, 2018 9:23 pm
I haven't tested method B via UECP yet so that's very well possible.
But, what's wrong with normal AF method B?
PostPosted: Mon Nov 05, 2018 9:58 pm
Hans, I got too many duplicated frequencies in pira's RDS spy.
Will have to check it out once more.
PostPosted: Tue Nov 06, 2018 4:52 am
Streaming AAC-HE using VLC input causes the GUI to stop/start/stop/start every ~300ms
The audio keeps playing fine.
For example, put this in as a stream source: http://radio.muppetz.com:5001/brianfm64
An MP3 stream (http://radio.muppetz.com:5001/brianfm) doesn't exhibit this.
PostPosted: Tue Nov 06, 2018 4:16 pm
Ah, that purely depends on how the stream comes in. If that's in bursts, then everything (including the GUI) will be updated in bursts.
Hm, I checked it with that. So.... can you show a screenshot or something like that? Thanks...
