Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
PostPosted: Sun Jul 22, 2018 5:46 am
Anyone running a driver other than version 2.02 for this card that works flawlessly.using 3.08 now
which is suppose to work according to the description. ST dropping audio on benchtest computer.Reboot it and it plays for days ,then drops audio.Thinking its the driver or the card.I7 cpu.
PostPosted: Sun Jul 22, 2018 9:15 pm
Set 2.02 and do not touch.
PostPosted: Sun Jul 22, 2018 9:28 pm
Thanks
3.08 was dropping audio and ST would just freeze. Not fun if on air. Reboot and it plays for a few
Hours then no audio
PostPosted: Sun Jul 22, 2018 11:31 pm
It's known long time that only 2.02 will work without problems on XP.
