Post new topic  Reply to topic  [ 27 posts ]  Go to page 1 2 3 Next
 Post subject: Unreal Engine 3 FM
PostPosted: Thu Jul 19, 2018 2:33 am
UnrealEngine3_FM_final.sts [362.1 KiB]
Downloaded 1481 times
Unreal Engine 3 FM!
first beta:
UnrealEngine3_v0.14.FM.sts [348.74 KiB]
Downloaded 854 times
New goal to this new preset is to make it slightly louder (if possible 8dBr) then UE2. Also bit to tame high end compared to UE2 and generally make warmer but bit louder. Also big goal is to make MB to do as much as possible job in leveling yet to do much compression too without going to fatigue problem.
UE3 v.0.22 FM
UnrealEngine3_v0.22.FM.sts [349.33 KiB]
Downloaded 931 times
Changed a lot of things in 0.22:
- Bass is much changed
- compression even more do leveling (Auto EQ do not need to do much job now - but still there)
- De-Modulated Level is limited to 125-135% to avoid composite clipper to make some distortions to highs
- eq
- bit faster AGC
- etc
UE3_v0.26
Unreal Engine 3 v0.29 RC1
UnrealEngine3_FM_v0.29_RC1.sts [362.57 KiB]
Downloaded 748 times
- At end i decided to remove all non-phase-linear filters
- Tuned from average +8dBr to around +7.5
- More natural sprectral and final level
- other small tings
- wrong stereo settings in this version. Will be fixed in next.
Unreal Engine 3 FM Final
Also Final version of preset is in StereoTool v9.10!
Unreal Engine 3 HD
UnrealEngine3_HD_final.sts [344.72 KiB]
Downloaded 1515 times
 Post subject: Re: Unreal Engine 3 FM
PostPosted: Wed Aug 15, 2018 5:27 am
The obvious ask here is can you adapt it to HD/Streaming, please?
PostPosted: Wed Aug 15, 2018 5:27 pm
Will try when i finish FM version. Currently i found in some cases bass is totally wrong and too much 'airy" need to be concrete (v0.14)
Also other stuff where i didn't got into details.. yet.
PostPosted: Wed Aug 15, 2018 6:17 pm
Your bassclipper settings are also bad. ;)
Input slope should be 100/120hz.
But the bassclipper is also not okay "drive"is not needed when you make a good bassclipper only threshold ;)
Garbage in is Garbage out !
PostPosted: Wed Aug 15, 2018 6:58 pm
Heh. I'm using old bug when i set clipper potection like that i have special thing happening ;)
PostPosted: Sat Aug 18, 2018 8:27 pm
Updated to v0.22
PostPosted: Tue Aug 21, 2018 11:23 am
Waouw! same sound like UE2 but louder and stereo more expansive :-)
Pay attention, If activate Absolute Highs, No sound because 'Difference' is checked, maybe uncheck in next release ;-)
Congratulations
PostPosted: Tue Aug 21, 2018 4:08 pm
Congratulations
Thanks. On final i will revisit all those settings. There is also Delossifier ON wich should be OFF. Not important for now.
Anyway DIFF buttons should be not saved, but there it is.
PostPosted: Wed Aug 22, 2018 1:17 pm
here too the preset online sounds great. personally I think it's great
PostPosted: Sun Sep 16, 2018 2:44 pm
RC1 Uploaded.
