PostPosted: Fri Jul 06, 2018 9:25 am
I'm ready to buy myself a new scope.
For electronics and for measuring MPX signals.
What are the min reqierements for measuring MPX signals (bandwith) etc.
@work I had a R&S but that is too expensive for me.
Thanks all,
Succes :)
PostPosted: Mon Jul 23, 2018 10:46 pm
The spec is rather complex and vague, so I don't even dare to try to tell you what it needs to support. There are some that support it, just get one of those.....
PostPosted: Sun Aug 19, 2018 10:46 am
Had some contacts with other techies about this thread, it seems it's a analog frequentie analyzer which can be over modulated.
New, you can't find them anymore, so I'm looking my eyes out for a 2nd hand analyzer.
PostPosted: Wed Sep 05, 2018 12:49 pm
Keep in mind that the tests aren't done with analog gear anymore either.
