 Post subject: Mountain Peaks
PostPosted: Sun Jul 01, 2018 7:21 am
Here's my latest, you'll need everything licensed its an FM preset.
I've changed this almost as many times as Hans has beta's, but as his list comes to an end, I think it's ready for release.
All I'll say is it's loud & clear, with a nice bass rumble & audio depth.
Immerse yourself in the audio.
Please let me know if you find any issues, or if the bass is too much?
Glenn Pritchard - Mountain Peaks.sts [115.22 KiB]
Downloaded 1187 times
 Post subject: Re: Mountain Peaks
PostPosted: Sat Jul 14, 2018 6:43 am
Here's an updated version.
You'll need everything licensed & using the latest beta, 9.02beta011
I've changed a few settings & moved a few things around. I think it has a smoother sound than version 1 & everything works better together now?
Let me know of any issues, & if you like it or not.
Glenn Pritchard - Mountain Peaks V3.sts [115.57 KiB]
Downloaded 1113 times
PostPosted: Sun Oct 14, 2018 7:59 am
Three more versions as it's evolved.
V36 is possibly the final unless I get feedback that it's bad, personally I think I might like V26 better?
V36 was finished using ST 9.10
You'll need to licence everything, & it's fairly heavy on the CPU, if you don't have the processing power, turn Stokkemask to legacy mode, or if you don't need it, turn it off.
I won't describe it too much, I'll let you listen & decide.
It's a different sound to what most would be used to though, & should stand you out from the crowd (in a good way I hope).
Designed for FM, but should sound good streaming too.
Please give feedback good or bad.
Mountain Peaks V26.sts [116.28 KiB]
Downloaded 984 times
Mountain Peaks V32.sts [116.25 KiB]
Downloaded 978 times
Mountain Peaks V36.sts [116.3 KiB]
Downloaded 1067 times
PostPosted: Sat Dec 01, 2018 9:18 am
I couldn't help myself, & the more I listened to Vers.36 the more I didn't like it, so here's a new version.
This one is crisp & clear across all bands, you'll hear every instrument & every note clearly, with a very nice, powerful but smooth warm bass, utilising the new Immersive Bass Filter.
With this one you'll be immersed in & feel the music.
It's CPU intensive if you use my FM settings, so make sure you've got plenty to spare. It uses everything licensed too.
Hope everyone likes it?
I want feedback, good or bad, so have a good listen, let it grow on you, & post your thoughts here.
NOTE: If you're using ST Ver. 9.12Beta012 turn off "Don't Boost Existing" in v0.85 to hear my desired effect (pre-set was built pre Don't Boost Existing in Beta012).
v0.87 has adjusted EQ to try to give a stronger Bass with "Don't Boost Existing" turned on, (may still need work depending upon what Hans does with Immersive Bass?).
Glenn Pritchard - Mountain Peaks v0.87.sts [124.03 KiB]
Downloaded 1009 times
Glenn Pritchard - Mountain Peaks v0.85.sts [124 KiB]
Downloaded 980 times
