Post new topic  Reply to topic  [ 18 posts ]  Go to page 1 2 Next
 Post subject: New default forum skin
PostPosted: Thu Jun 14, 2018 2:45 pm
A new forum skin just went live.
If you prefer the old skin, or the new one is unusable in any way, please let me know why.
I will try to fix it as soon as possible.
UPDATE:
The old skin is no longer available, to make sure that every used sees the new style. We might re-enable it in a week or so. By that time, you can revert back to it by going to:
User Control Panel > Board preferences > My board style:
And choose the style subsilver2.
PostPosted: Thu Jun 14, 2018 5:00 pm
Looks nice!
I had to manually switch to Thimeo Light, maybe I explicitly selected the old one at some point.
PostPosted: Thu Jun 14, 2018 9:20 pm
Good evening t.j.evers,
beautiful skin, I adopted it, I like it ;)
PostPosted: Thu Jun 14, 2018 9:24 pm
Some topics not visible as in old. Also still some functions not working for mods/admins.
PostPosted: Fri Jun 15, 2018 12:25 am
This is lovely, much nicer than the old :)
PostPosted: Fri Jun 15, 2018 11:12 am
Can you PM me with some examples?
PostPosted: Fri Jun 15, 2018 2:45 pm
I applied a small update, administration/moderator control panel should be back now.
Also, whitespace wrapping around the top bar (notifications, private messages, logout, faq, etc.) should now work as expected.
Use CTRL+F5 to make sure the newest style files are loaded when you're already using Thimeo Light.
PostPosted: Fri Jun 15, 2018 9:52 pm
Need to ask, are you now man who is in charge for forum?
btw, still i cannot, for exmple, make this topic "sticky"
Re-checked some topics.. seems all is same in both skins.
PostPosted: Sat Jun 16, 2018 12:30 pm
He's our new colleague and he couldn't stand the look of the old forum, so he took charge of things ;)
PostPosted: Sat Jun 16, 2018 6:51 pm
good :)
