 Post subject: Bass EQ
PostPosted: Fri Dec 22, 2017 1:47 am
Not hearing much feedback on this feature. Thoughts?
 Post subject: Re: Bass EQ
PostPosted: Sat Dec 23, 2017 1:18 am
I thought it was well worth including in the product. There's a lot to Stereo Tool, yet here's another feature that brings something useful to the table.
The Bass EQ does a good job of smoothing out various levels of low frequency input, yet it is unobtrusive in its own operation. If you subscribe to the "less is more" concept of audio processing, then Bass EQ allows you a consistent sound without the need for more bass compression in the MB sections than you might otherwise need to use.
I've used it on AM and FM. Gets a thumbs-up from me...
PostPosted: Sat Dec 23, 2017 3:11 pm
Fully agree with you RodeoJack,
Keep the good vibes up :-)
