 Post subject: Tropical Breeze
PostPosted: Fri Oct 27, 2017 4:42 am
Here's my latest, & I think best I've done.
It's well balanced across the spectrum, loud but heaps of dynamic range (if it's in the source), very clean & clear sound.
Very airy sound with wide stereo, feel surrounded by the sound.
Has a nice bass rumble when it's meant to.
Suits all types of music, from classical through to metal.
Has all the new features of 8.54 beta 004 & all licensed features.
The sound just happened when everything gelled together with Hans's latest features, but make your own mind up.
Please post comments if you like or what's wrong if you don't like.
Made for FM, but will sound good on a web stream too.
It's a full export file, take the settings out of it you need.
Glenn Pritchard - Tropical Breeze 8.54.sts [111.51 KiB]
Downloaded 713 times
 Post subject: Re: Tropical Breeze
PostPosted: Wed Nov 08, 2017 2:48 am
I've taken some comments on board, that the original preset was a little hard to listen to after a while, on some audio systems, so I've done some tweaks to hopefully take the edge off the sound, & made up 3 more presets, but I'm not sure what ones best, so need your input.
There's not a lot of sound difference between them, one has less density & is a bit brighter with an almost source sound, the others have some reasonable bass rumble.
Please comment, good or bad for long listening times.
They are named on what ST version they were made with, 8.54 beta009 has 2 preset versions.
Glenn Pritchard - Tropical Breeze 8.54beta007.sts [111.64 KiB]
Downloaded 538 times
Glenn Pritchard - Tropical Breeze 8.54beta009.sts [111.72 KiB]
Downloaded 539 times
Glenn Pritchard - Tropical Breeze 8.54beta009v2.sts [111.66 KiB]
Downloaded 624 times
