 Post subject: My new preset Stream/FM
PostPosted: Thu May 20, 2010 11:28 pm
Here is my current preset that i am using for our transmitter and stream
Only difference between stream and fm is Lowpass filter, FM-16kHz and for stream 17.5kHz
This should try all who thinks that StereoTool 5 has more highs!
(use latest beta)
http://www.stereotool.com/download/ster ... _BETA2.exe
If someone wants to check, please feel free to comment.
note: still not final.
edit: set postamp and preamp
ST5_EL34.rar [2.32 KiB]
Downloaded 869 times
PostPosted: Sat Jul 24, 2010 4:06 pm
hello bojcha , i listen radiodak and wow , good sound !!! :o
i try the last version of stereo tool 5.02 on my stream , can you say me if my sound is good too?
http://94.23.192.221:8704/listen.pls
PostPosted: Sun Jul 25, 2010 12:24 am
Hi Garfield...
First, i don't use this preset on that stream, heh, constanlty is changed till today and i am using some test version of stereotool which is bit different from standard stereotool.... testing. I do some improvements with master signal thru radio. Now i use Digital Coaxial output from "SRC2496" to send it to FM and stream PC. Both PCsa are with Juli@.
If we soon get another licence for another radio, there will be better music :).
About your stream ..
Nice sound, today was bit louder then it should but tonight level is lower/better.
If you ask me.. just lower a bit deep/lows.
Good attenuation.
