 Post subject: question
PostPosted: Thu May 06, 2010 11:02 pm
Hello Hans ,
I cant stand to write this , because of a little bit of worry .
In the CSS ( complex stereo signal ) there are harmonics of the RDS signal and pilot signal ..... I attach this screen to show You . So i think that there is a way to cut out this harmonics ? How about this ?
I try to make a PM but not allowed extention of JPG BMP PNG ect....
 Post subject: Re: question
PostPosted: Thu May 06, 2010 11:26 pm
Hi DJ-Doggy,
I've seen this in the past. What I eventually found out is that VAC, which is also used by MpxTool, needs to be set to the output frequency of Stereo Tool - and you have to configure that in VAC! If you don't, you get this type of effects. The other frequencies are NOT present in the signal that Stereo Tool sends out!
So if Stereo Tool sends out 176400 Hz, then VAC must also be set at 176400.
PostPosted: Fri May 07, 2010 11:00 am
Ha ... Damn...... Hans You are right :)
My worry is GONE . Thanks
PostPosted: Fri May 07, 2010 1:45 pm
always set VACs to 192000-192000 .. all will be good
